Crank Position Sensor Help #986401 02/20/10 02:30 AM
cincymontero Offline OP
I am looking at another 90 lwb after mine blew. The guy says it needs a crank position sensor. It wont start. Is this an easy replacement, as I have a donor monty? Where is it located? Could it be the crank bolt problem instead? Any help would be great. I have never dealt with this before. Thanks
Re: Crank Position Sensor Help [Re: cincymontero] #986402 02/20/10 03:03 AM
hazy_daze Offline
There's not a crank sensor on it. There is an optical sensor in the distributor that has a fairly high fail rate. Easy fix if you can swap the distributor from your parts car and assuming it's the same.
EDIT: Oh and the crank bolt issue is pretty obvious when it turns over. The harmonic balancer doesn't turn with the engine, it's broke.
Re: Crank Position Sensor Help [Re: hazy_daze] #986403 02/21/10 04:23 PM
Thanks for the info.
PHP: 7.4.33 Page Time: 2.526s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-06-20 20:58:33 UTC
