Page 3 of 4 1 2 3 4
Re: '95 Monty SR 3.5 ATF recommendation [Re: haztoys] #986507 02/23/10 01:25 AM
StockRaider Offline
I think at this point Scottie is the only one, everyone else who did had to replace their transmission. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: '95 Monty SR 3.5 ATF recommendation [Re: StockRaider] #986508 02/23/10 02:08 AM
Kevin C Offline
I ran Mobil 1 in mine and it was fine (mine is a non electronic control model) . I stopped because it was too expensive and if I have a problem I just rebuild the unit. Last I checked I was spending as much on Mobil 1 as I did for a banner kit. <img src="/forums/images/graemlins/lol.gif" alt="" />
Kevin
Re: '95 Monty SR 3.5 ATF recommendation [Re: Kevin C] #986509 02/23/10 05:32 AM
Just don't put the valve in backwards again...
"It's obnoxious that the elephant never forgets"...
Re: '95 Monty SR 3.5 ATF recommendation [Re: fasteddy] #986510 02/23/10 05:40 AM
Kevin C Offline
Eddy,
Dang your good!!!! Till now I had almost forgotten about that.
Re: '95 Monty SR 3.5 ATF recommendation [Re: Kevin C] #986511 02/23/10 05:49 AM
I have found it useful to remember mistakes. It is less painful to remember the mistakes of others, but all of them are useful to remember...
Re: '95 Monty SR 3.5 ATF recommendation [Re: fasteddy] #986512 02/23/10 07:57 PM
scottiesharpe Offline OP
Mobil 1 ATF and Diamond SP III are the same price: $6 / qt.
Scottie Sharpe
Sunny San Jose CA
Webmaser for BMW TURBOS! Forum
http://bmwturbos.scottiesharpe.com
1995 Montero SR
Re: '95 Monty SR 3.5 ATF recommendation [Re: scottiesharpe] #986513 02/23/10 08:11 PM
Kevin C Offline
I should have mentioned that my 1990 unit takes Dexron. Great price on the Mobil 1, where are you buying from? I hear Wal-Mart had good prices but I have not checked them out.
Re: '95 Monty SR 3.5 ATF recommendation [Re: StockRaider] #986514 02/23/10 09:51 PM
P
pcc Offline
In 2004 and 112k on engine I flushed trans oil with Redline C+ATF. No problems with tranmission. In 2008 and 138k on engine I flushed trans oil with Mobil1 Synthetic ATF - Multi-Vehicle, so far no problems and 8000mi on oil. The Mobil1 label on the back reads:
"Mobil1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles."
"Also suitable for use in automatic transmissions for the following applications..... Mitsubishi Diamond SP-II, SP-III.."
I'll let you know if my trans fails.
Re: '95 Monty SR 3.5 ATF recommendation [Re: pcc] #986515 02/23/10 10:48 PM
Thanks for the update.
Any one else currently running Mobil 1?
Scottie Sharpe
Sunny San Jose CA
1995 Montero SR
Re: '95 Monty SR 3.5 ATF recommendation UPDATE [Re: scottiesharpe] #986516 05/03/10 04:19 PM
Just passed 2k miles on the Mobil Synth ATF.
Scottie Sharpe
Sunny San Jose CA
1995 Montero SR
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6413 MB (Peak: 0.7483 MB) Data Comp: Off Server Time: 2026-05-29 16:21:29 UTC
