Re: '95 Monty SR 3.5 ATF recommendation
[Re: haztoys]
#986507
02/23/10 01:25 AM
I think at this point Scottie is the only one, everyone else who did had to replace their transmission. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#986508
02/23/10 02:08 AM
I ran Mobil 1 in mine and it was fine (mine is a non electronic control model) . I stopped because it was too expensive and if I have a problem I just rebuild the unit. Last I checked I was spending as much on Mobil 1 as I did for a banner kit. <img src="/forums/images/graemlins/lol.gif" alt="" />
Kevin
[Re: Kevin C]
#986509
02/23/10 05:32 AM
Just don't put the valve in backwards again...
"It's obnoxious that the elephant never forgets"...
[Re: fasteddy]
#986510
02/23/10 05:40 AM
Eddy,
Dang your good!!!! Till now I had almost forgotten about that.
[Re: Kevin C]
#986511
02/23/10 05:49 AM
I have found it useful to remember mistakes. It is less painful to remember the mistakes of others, but all of them are useful to remember...
[Re: fasteddy]
#986512
02/23/10 07:57 PM
Mobil 1 ATF and Diamond SP III are the same price: $6 / qt.
[Re: scottiesharpe]
#986513
02/23/10 08:11 PM
Mobil 1 ATF and Diamond SP III are the same price: $6 / qt. I should have mentioned that my 1990 unit takes Dexron. Great price on the Mobil 1, where are you buying from? I hear Wal-Mart had good prices but I have not checked them out.
[Re: StockRaider]
#986514
02/23/10 09:51 PM
In 2004 and 112k on engine I flushed trans oil with Redline C+ATF. No problems with tranmission. In 2008 and 138k on engine I flushed trans oil with Mobil1 Synthetic ATF - Multi-Vehicle, so far no problems and 8000mi on oil. The Mobil1 label on the back reads:
"Mobil1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles."
"Also suitable for use in automatic transmissions for the following applications..... Mitsubishi Diamond SP-II, SP-III.."
I'll let you know if my trans fails.
[Re: pcc]
#986515
02/23/10 10:48 PM
Thanks for the update.
Any one else currently running Mobil 1?
Re: '95 Monty SR 3.5 ATF recommendation UPDATE
[Re: scottiesharpe]
#986516
05/03/10 04:19 PM
Just passed 2k miles on the Mobil Synth ATF.
