Re: What is the best size rim for 35's on a GEN2?
[Re: MBrannon]
#986640
02/23/10 10:31 AM
As you drop pressure, you're going to encounter more problems with a wider wheel compared to your tire size.
This weekend, I was running my 33x12.5's on my above mentioned 7" wheels with no problem at 12 psi, yet Pa_Jero had a leak problem with his 35x12.5's on his 10" steel wheels at 20 psi after one of them bumped a rock and bent his steelie a little. A hammer was brought out to fix it and stop the leak.
I just feel like I can better protect my rim and bead by using a narrower wheel while compensating for the high street pressure-related tread-edge lift by carefully noting the contact patch and adjusting accordingly. I've never popped a bead, by the way, and my tires have always worn normally. I have predictable handling, even in emergency situations. They stand taller...but I guess they just don't look as cool? I dunno...
[Re: JohnnyBfromPeoria]
#986641
02/24/10 02:46 AM
yall have any pics of 35's on stockers?
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#986642
02/24/10 04:27 AM
there is a guy on craigslist parting out a chevy truck with 31s and some 15" steelies 6lug
i emailed he wants $200
I don't need them, do you want his email?
edit: 200 for both tires/wheels, stick the 31s on the gen1
[Re: MBrannon]
#986643
02/24/10 04:33 AM
Come to think of it, MBrannon, I don't think I, personally, have seen 35's on stockers, yet. Maybe I have and just missed it. I think I'll be going 35's next time, so stay tuned and I'll stay stock.
#986644
02/24/10 07:57 AM
Oh yeah JBFP 35's rock you'll never look back, 35's make a world of difference especially on a LWB.
[Re: TOASTY]
#986645
02/24/10 02:45 PM
I think I saw that truck on Craigslist too. Problem is I have BRAND NEW tires on the GEN1! Hmmm, maybe I should get the 31's and sell my brand new street tires. The future of the GEN1 is questionable right now. Debating between fixing it, selling it, or twin turboing it. Anyways, shoot me the guys email  thanks
[Re: MBrannon]
#986646
02/24/10 05:09 PM
My vote is for the twin turbo, for what it's worth.
#986647
02/24/10 05:45 PM
This weekend, I was running my 33x12.5's on my above mentioned 7" wheels with no problem at 12 psi, yet Pa_Jero had a leak problem with his 35x12.5's on his 10" steel wheels at 20 psi after one of them bumped a rock and bent his steelie a little. A hammer was brought out to fix it and stop the leak. 35s are heavier and do not conform to the rim as well as 33s and smaller. By that, the lip of the tire on 35s is thicker. I went from 33s to 295 (34 inch) and had to replace the rims. The 33s held air where the bigger tires would not seat correctly on one rim. Close inspection showed it was slightly out of round. I have since shifted to alloy (with 35s) as they are less likely to bend. I did bread a 6 inch chunk off and the 35s still held air. Check the fitment guide from the tire manufacture for the recommended wheel width. An 8 inch rim should work fine with 31-35 inch tires.
