Re: Vehicle VIN number repository.
[Re: bearingman]
#987713
07/20/10 07:24 PM
Here's mine. It is SUPPOSED to be a 89 Montero 3.0 5 speed, A/C, tilt, PW, PL, cruise. Badged as a Sport, but from my understanding 89 Sports only came with auto's??
JA7FJ43S7KJ007467
i MIGHT ADD, IT CAME WITH A RECONSTRUCTED TITLE, SO?????? Mitsu ASA shows it with a manual tranny based on that VIN number. Not sure about the other accessories you noted but you can probably check for yourself. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#987714
07/20/10 07:39 PM
1994 Montero: LS w/ the ???? ???? engine & manual transmission JA4MR41H4RJ002466 1996 Montero: LS w/ the ???? ???? engine JA4MR41H1TJ006398
The 94 will be 3.0 12V SOHC and the 96 3.0 24V DOHC. Those would be for LSs, as indicated.
[Re: off-roader]
#987715
11/03/10 06:02 AM
JA7FJ43S7KJ007467
i MIGHT ADD, IT CAME WITH A RECONSTRUCTED TITLE, SO?????? Mitsu ASA shows it with a manual tranny based on that VIN number. Not sure about the other accessories you noted but you can probably check for yourself. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Soory to highjack, but is there anyone who can post a link to the ASA software? TIA <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: MrJeebs]
#987716
11/03/10 07:56 AM
Read the FAQ thread at the top of the forum.
[Re: off-roader]
#987717
01/17/11 05:55 AM
It would be good if you guys in Africa/Asia/Australia could give us some salvage yard vins. SWB and diesel info would help with our convertions to diesels, etc.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#987718
01/24/11 07:57 AM
Mine
1997 MONTERO LS w/3.5L SOHC JA4MR41R5VJ011891
Curious the build date says March 1997 but the vin says 1998. Is this a 97 or 98?
[Re: MCMILO]
#987719
01/24/11 05:23 PM
Per ASA, it's 33rd week of production for model year 97, still making it a 97. Your 10th digit is a V, which is 97. A 10th digit of W would indicate a 98. Learn more about VIN decoding here.
[Re: off-roader]
#987720
12/19/12 04:52 AM
Is this thread still active? I just joined, and I'd like to throw my Montero into the Mix. It's a 1990 Montero RS, 3.0 sohc, 5sp manual, VIN JA4GJ41S7LJ003747
--1990 Montero, 3.0L V6, 5sp Manual--
[Re: Stoicwatchman]
#987721
12/19/12 05:41 AM
Is this thread still active? I just joined, and I'd like to throw my Montero into the Mix. It's a 1990 Montero RS, 3.0 sohc, 5sp manual, VIN JA4GJ41S7LJ003747 Welcome! Yes it is. I'll add it, thanks!
[Re: off-roader]
#987722
09/15/13 09:11 PM
I thought mine was already on here since it belonged to a member. 89 dodge raider 3.0 auto JB7FJ43S9KJ017243
Once this added how will I be able to put this into caps?
