Page 3 of 5 1 2 3 4 5
Re: vin #s for lsd [Re: Dryver] #988313 03/05/10 01:27 AM
jaboo5322 Offline
also lsd in the air spins opposit direction
Well guys, I just put mine up in the air per request. Transfer case in neutral (manual shift.. no neutral position on automatics), transmission in neutral just to be sure. Spin one wheel by hand and the other spins.... in the SAME direction. Very tightly bound together, as well.. no lag. Spin one, the other spun in the same direction immediately.
Not sure what Jay has if his is spinning opposite directions. Maybe a broken or worn out LSD?
Now the thing I found interesting is this: The neutral position on the manual transfer case is between 4H and 4L (typical). When I spun the rear wheel, the rear drive shaft spun, which I expected, but the front drive shaft spun also. That means the front and rear output of the transfer case are tied together when in neutral, but disconnected from the transmission. This must be why it's recommended to remove the rear drive shaft if you tow it for long distances.
What the heck does it do in park. If there was no drag, potentialy a diff would spin in the same direction in neutral. Generaly the other wheel would go opposite because of drag and it's easier to turn the spiders, but to check for lsd, you will definately feel the clutch's drag when in park to get the other wheel to turn opposite.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: vin #s for lsd [Re: jaboo5322] #988314 03/05/10 01:32 AM
jaboo5322 Offline
A good read. <img src="/forums/images/graemlins/smile.gif" alt="" />http://en.wikipedia.org/wiki/Limited_slip_differential
Re: vin #s for lsd [Re: jaboo5322] #988315 03/05/10 01:48 AM
6
69442 Offline
Good read if I could open it, link doesn't work <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: vin #s for lsd [Re: 69442] #988316 03/05/10 01:58 AM
jaboo5322 Offline
I know, it's hard to copy and paste. <img src="/forums/images/graemlins/lol.gif" alt="" />
1989 Dodge W250.
Re: vin #s for lsd [Re: jaboo5322] #988317 03/05/10 03:32 AM
Dryver Offline
I have a manual transmission, so I don't have park. I didn't care to try to spin them in gear, as I would be essentially trying to turn over the engine by turning the rear wheel. The rear diff that I was told was an LSD by the junkyard that I went to try to pick up before I got this one was completely off the car, no driveshaft and no wheels. When I turned one hub by hand on that one, the other side spun opposite, which is why I passed on it.
If you really want me to, I'll try again tomorrow with the car in gear and post the result. Won't be til the afternoon, though.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: vin #s for lsd [Re: Dryver] #988318 03/05/10 04:03 PM
jaboo5322 Offline
Well, my local dealer said sure i can buy an lsd from them, for alot, but the vin doesn't really say whether or not it came with lsd. He said maybe a tag somewhere, maybe the door tag with the vehicle wt. and date of manufacture. Maybe someone else will have more luck. <img src="/forums/images/graemlins/smile.gif" alt="" />
1989 Dodge W250.
Re: vin #s for lsd [Re: jaboo5322] #988319 03/05/10 04:35 PM
Dryver Offline
Kia can tell from the VIN somehow whether the car had a LSD in it or not. I don't know if there is a specific digit in the VIN that tells them this, or if they have to cross check with manufacturing records. When I was checking junkyards for a LSD, if I called Kia customer service with the VIN, they could tell me whether the car originally had LSD or not. (Except for one guy that I got once who apparently couldn't figure it out)
Re: vin #s for lsd [Re: jaboo5322] #988320 03/05/10 04:47 PM
6
69442 Offline
I called my local dealer yesterday as well. Parts guy says just running the VIN # tells him a lot of things but doesn't specifically say ya or na on LSD. But ... when the VIN # is entered and he goes into the part selection for LSD, it should either light up or not light up as a applicable part for that rig.
So what he's saying is, just having a dealer run a VIN # won't help you one bit! The combination of the VIN # and looking into their parts system for a specific part is the only way to determine if LSD was installed from the factory.
So, if any of us are trying to confirm whether a wrecking yard rig has LSD or not, call your local dealer. Ask for the Parts Mgr, have them run the VIN # on that particular rig then look up the rear Diff options to see if LSD lights up on their system.
Of course this is assuming all stealership parts systems are the same so good luck.
Mine did not light up <img src="/forums/images/graemlins/angry.gif" alt="" /> G** D*** M***** F****** Son of a B**** <img src="/forums/images/graemlins/lol.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: vin #s for lsd [Re: 69442] #988321 03/05/10 11:00 PM
Hydra747 Offline
Very good INFO to know! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: vin #s for lsd [Re: Hydra747] #988322 03/06/10 03:20 AM
jays2001 Offline OP
the last eight digits of the vin is the key. the dealer said my vin is a lsd and i did mine in park so i dont know but like u guys have said and i know mine is busted
but not next week <img src="/forums/images/graemlins/evil.gif" alt="" /> the idiot at the dealer told me the new lsd is 700bucks wrong try 900 and some change the other is the open i talked to a guy in person made him varify and show me it was and ordered it stole it for 800 because the other tool priced it wrong <img src="/forums/images/graemlins/nana.gif" alt="" /> i know pricccee <img src="/forums/images/graemlins/scared.gif" alt="" /> but warranty is worth it <img src="/forums/images/graemlins/kewl.gif" alt="" />
when i take mine apart i will let u know if it is a lsd or not and im going to rebuild it if so to sell or use as a back up <img src="/forums/images/graemlins/patriot.gif" alt="" /> ill take photos of the tear down and stuff and of my body lift i know some have been wanting pics of that and i have been alittle lazzy about it and now that im going to be under there ill getter done. <img src="/forums/images/graemlins/shiner.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6467 MB (Peak: 0.7587 MB) Data Comp: Off Server Time: 2026-11-02 12:30:34 UTC
