Re: vin #s for lsd
[Re: jays2001]
#988323
03/06/10 04:39 AM
the last eight digits of the vin is the key. the dealer said my vin is a lsd and i did mine in park so i dont know but like u guys have said and i know mine is busted
but not next week <img src="/forums/images/graemlins/evil.gif" alt="" /> the idiot at the dealer told me the new lsd is 700bucks wrong try 900 and some change the other is the open i talked to a guy in person made him varify and show me it was and ordered it stole it for 800 because the other tool priced it wrong <img src="/forums/images/graemlins/nana.gif" alt="" /> i know pricccee <img src="/forums/images/graemlins/scared.gif" alt="" /> but warranty is worth it <img src="/forums/images/graemlins/kewl.gif" alt="" /> when i take mine apart i will let u know if it is a lsd or not and im going to rebuild it if so to sell or use as a back up <img src="/forums/images/graemlins/patriot.gif" alt="" /> ill take photos of the tear down and stuff and of my body lift i know some have been wanting pics of that and i have been alittle lazzy about it and now that im going to be under there ill getter done. <img src="/forums/images/graemlins/shiner.gif" alt="" /> Part Number: 0k04827200a List Price Core Price Your Price Universals & rear axle - Rear axle - Differential - Differential assy Differential assy, sportage, w/limited slip 1995 - 2002 retail $869.08, wholesale $636.17 Part Number: 0022127350 List Price Core Price Your Price Front drive axle - Drive axles - Differential - Side bearings Side bearings, sportage 1995 - 2002 retail $33.45, wholesale $24.52 need 2 bearings
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
Re: vin #s for lsd
[Re: bombardj1]
#988324
03/06/10 04:47 AM
Just out of curiosity, did anyone read the link i put up. Cause i felt bad posting like i knew everything, then i read and found not all lsd's act the same. I imagine the kia's do. Dryver, did you do it in gear yet? <img src="/forums/images/graemlins/kewl.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter. 1989 Dodge W250.
Re: vin #s for lsd
[Re: jaboo5322]
#988325
03/06/10 03:55 PM
Just out of curiosity, did anyone read the link i put up. Cause i felt bad posting like i knew everything, then i read and found not all lsd's act the same. I imagine the kia's do. Dryver, did you do it in gear yet? <img src="/forums/images/graemlins/kewl.gif" alt="" /> Of course we read it and we didn't take it as though you knew everything, you were just posting good info. I had a Detroit Locker in a muscle car back in the day, I would love to try that out wheel'n in the Sporty <img src="/forums/images/graemlins/kewl.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting ..... ____o_o l_l_l\___\___ l----[o]==[o] l----==[--]== ()_)()_)--()_)
Re: vin #s for lsd
[Re: 69442]
#988326
03/06/10 05:44 PM
INSPECTION 1. Jack up one wheel. 2. While the other wheel is on the floor, and using a torque wrench of at least 200 lbÀft (271 NÀm), test the breakaway torque required to start rotation. The torque required to start rotation should be at least 20 lbÀft (27 NÀm). Normally, the initial breakaway torque will be higher than the continuous turning torque. The axle shaft should turn with even pressure without binding throughout the test. 3. If the torque reading is less than specified or if driving tests reveal abnormal chatter, the differential case should be replaced. Refer to ôDifferentialö under ôOn-Vehicle Serviceö in this section.
Ok, sorry dryver. You basically checked it like kia wants. I think you could judge the resistance without actually using a torque wrench. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: vin #s for lsd
[Re: bombardj1]
#988327
03/06/10 07:47 PM
hey bomb where did u get those prices and are they new
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: vin #s for lsd
[Re: jays2001]
#988328
03/06/10 08:51 PM
kiaparts.com new dealer parts
just type in kiaparts in search engines, should get othe sires too
Re: vin #s for lsd
[Re: jaboo5322]
#988329
03/06/10 10:58 PM
Dryver, did you do it in gear yet? <img src="/forums/images/graemlins/kewl.gif" alt="" /> Yeah, I read the article you posted. Says LSD should act like an open diff with it in gear once you overcome the friction plates. Just put in up in the air again and left it in 1st gear. Took significant force to turn by hand, and the other wheel did in fact turn the opposite direction. If you find this EASY to do by hand, you either have an open diff or a worn out or broken LSD.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
Re: vin #s for lsd
[Re: Dryver]
#988330
03/07/10 04:35 AM
that sucks i done ordered it so im screwed already but they have to do all warranty work so i guess ill live.
Re: vin #s for lsd
[Re: jays2001]
#988331
03/07/10 02:09 PM
that sucks i done ordered it so im screwed already but they have to do all warranty work so i guess ill live. Have tou tried lifting the rear in neutral and spinning one wheel or the driveshaft by hand to see if both wheels turn the same direction? You still may need the new one if yours is screwed up. Remember to block the front wheels so she doesn't run away on you.
Re: vin #s for lsd
[Re: Dryver]
#988332
03/07/10 07:28 PM
the one i ordered is locking so i will check the one i have in neutral this time and see what i get here in awhile <img src="/forums/images/graemlins/patriot.gif" alt="" />
