Re: vin #s for lsd
[Re: jays2001]
#988333
03/07/10 09:37 PM
hope you went ahead and ordered new bearings and seals both at the LSD and axles, your going to have it all torn apart anyway
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
Re: vin #s for lsd
[Re: bombardj1]
#988334
03/08/10 01:33 AM
yes sir i did same thought i had its apart and in the air fix everything now none later. <img src="/forums/images/graemlins/kewl.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: vin #s for lsd
[Re: jays2001]
#988335
03/28/10 12:56 AM
well it is done finale today started it and finished in about three hours and a few <img src="/forums/images/graemlins/cheers.gif" alt="" /> later. the lsd was easy and my original was open even tho dealer said no i have photos will post of the hole deal in next day or so,the old one the pin down the spider gears was coming out and met the pinion gear and was not pretty.dont know what happen there but all fixed and better now <img src="/forums/images/graemlins/kewl.gif" alt="" /> cant wait to go wheeling on the 17 of next month <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: vin #s for lsd
[Re: jays2001]
#988336
05/09/10 08:45 PM
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6105 MB (Peak: 0.6829 MB) Data Comp: Off Server Time: 2026-11-02 03:50:54 UTCValid HTML 5 and Valid CSS
