Page 1 of 3 1 2 3
Fuso ring gear size = 9.5"=SR ring gears? #988431 03/04/10 09:36 PM
off-roader Offline OP
Bear with me and the following run-on / train of thought...
Is what I've been hearing reading correct? The Gen 2 SR & Gen 2.5 Winter Package rear diff's ring gear is a 9.5" gear which is the same size as a Fuso Canter's ring gear and the Canter is sold as the FE model by Fuso USA and Fuso FE's may have come with a 5.29:1 gear ratio which therefore means there's a 5.29:1 ring & pinion available for my SR?!? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
TIA.
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: off-roader] #988432 03/04/10 10:12 PM
hazy_daze Offline
Yes. I've been searching for this for awhile now. They do exist. I haven't gotten a part number yet. My Mitsu parts guy has said that he'd pay for the J a p a n e s e ASA to order them for me and then cancel it. As it progresses, I'll update in this thread.
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: off-roader] #988433 03/04/10 10:17 PM
hochkis Offline
TIA.
Well Now i'm excited.... been a while since i have seen a fuso up close, and i didn't have a montero at the time but the axle does seem very similar all together. might even be the same third member. <img src="/forums/images/graemlins/notooth.gif" alt="" />
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: hochkis] #988434 03/04/10 10:55 PM
hazy_daze Offline
Fuso's in the US are too big. The Canter is a smaller version that was never offered here.
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: hazy_daze] #988435 03/05/10 12:59 AM
lordtrunks Offline
YOu'll be looking for the 2.8 diesel powered canter it uses the pajero drive train, misterbishi,toasty and i looked into this years back and what we found was 5.29's BUT the canter axle is FULL FLOAT and may have a different carrier than what we have. If you can find the Ring and pinion i'm sure if we just order 1 set and have a few of us pitch in on it then someone test fit it and if it doesn't fit no ones really out that much. I'll throw down some cash for it. Our fuso dealer was able to get it but we had to buy the whole 3rd member and it was $1000 so we passed.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: lordtrunks] #988436 03/05/10 01:17 AM
Can your fuso dealer pull up the part number for just the ring/pinion gear? I might have a source via the Philippines. I recently learned that some of my cousins drive or used to drive Pajero's there. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: off-roader] #988437 03/05/10 02:03 AM
PHIL_ Offline
Interesting stuff. My 490s work for my truck, but for those with 460s it would be a big upgrade on bigger than stock tires.
Ray, where are your revs sitting at on the highway, in OD, at say, 60mpg, on 35s?
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: PHIL_] #988438 03/05/10 03:45 AM
0778drz110 Offline
what about the front? or are they 4wd?
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: PHIL_] #988439 03/05/10 03:56 AM
sparkem Offline
The H and the G make a huge difference. We know what you mean.
Re: Fuso ring gear size = 9.5"=SR ring gears? [Re: 0778drz110] #988440 03/05/10 03:58 AM
lordtrunks Offline
No part number he called a different country I can't remember which and they had one, you see Fuso dealers are also junkyards so you can buy new and used parts from them, have your friends ask about a used set as well ray. As far as the front canter axle i don't what it uses I know its solid and could be a front version of the 9.5 but it will also be full float.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6457 MB (Peak: 0.7713 MB) Data Comp: Off Server Time: 2026-11-14 11:46:43 UTC
