i need a driveshaft bearing #988464 03/05/10 01:48 AM
Dave Scott Offline OP
ok, i have a 2wd 2002 sportage. i have seen two websites that sell an entire driveshaft, tranny to rear axle for almost $400... i can't afford that. one of them also sells the center bearing alone for $89 and change. i want to find that cheaper. anybody know anything? also, anyone know for sure how to change it? looks like you unbolt and remove the rear flange and then press the bearing off, then press a new bearing on and bolt the flange back on. any help is appreciated.
just went to the junk yard and got one today, bolted it in and it vibrates pretty bad on take-off too, the original one blew on the highway... don't want that happening again.
thx for anything guys...
-dave
Re: i need a driveshaft bearing [Re: Dave Scott] #988465 03/05/10 03:11 AM
Hydra747 Offline
Got just what you need....Since my conversion....
Let me know... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: i need a driveshaft bearing [Re: Hydra747] #988466 03/05/10 03:21 AM
pm-ing you now...
Re: i need a driveshaft bearing [Re: Dave Scott] #988467 03/05/10 03:24 AM
Hydra747 Offline
k....
Re: i need a driveshaft bearing [Re: Dave Scott] #988468 03/05/10 01:43 PM
bombardj1 Offline
the center you can order wholesale if they have them on-line for about $60 the bering between it and the flange I think is about $30 wholesale, wholesale for the total shaft with all new parts is just under $400 bucks alot of money, but it's all new stuff. the book does say the mt. at. are different part #'s for the total shafts, maybe the tranny's are different lenghts
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: i need a driveshaft bearing [Re: bombardj1] #988469 03/05/10 05:06 PM
thanks, basically, all i need is the bearing...
Re: i need a driveshaft bearing [Re: Dave Scott] #988470 03/05/10 10:40 PM
Hydra747 Offline
I guess that you saved all of your PM from 10 yrs......IT Says that you have exceeded your PM quota !!!!
Purge some of your stuff please or you can't get any more PM's.........
Mikey
Re: i need a driveshaft bearing [Re: Hydra747] #988471 03/06/10 04:43 PM
done...
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6221 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-06-06 20:27:13 UTC
