Front LSD
#988548
03/05/10 04:45 PM
After reading about Torsen LSD's and how they act like an open diff if one wheel is in the air, I was searching the internet in hopes of finding a better option for the front. Turns out that a Japanese company called OG Giken makes a product called Super Lock LSD. It's supposed to be "the best LSD available" with less heat creation and 100% lockup capability. They miniaturized the componentry to allow them to fit 28 friction plates into the unit. They make one that fits 94-05 1.8 Miatas, so I'm thinking this may be a drop-in for our front diff? The downside? Costs something like $1300 to $1500. Ouch! http://www.osgiken.net/products/superlock.htmlhttp://miataroadster.com/miataosgiken.html
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
Re: Front LSD
[Re: Dryver]
#988549
03/05/10 10:00 PM
I believe mine is a 87 RX7 NON-TURBO. It uses clutch plates and you can shim it so that it is tighter. If you get a whole rearend with the stub axles, you can check the brake away torque with a torque wrench. The one I have started @ 20 ft lbs and after shimming it, well guess the shim was too thick cause it jumped up to 90 ft lbs. I know that if you really work at it you can shove an extra plate in it and it will give you about 180 ft lbs which is like locked. Think I will re-shim it and get it down to about 65 ft pounds. More aggressive than stock (40) but 90 seemed not forgiving enough.
Good luck, I got a whole rear diff with stub axles for $50 off craigslist. The ring and pinion were fried but the lsd plates were just worn.
Let us know what direction you go.
Everet
PHP: 7.4.33 Page Time: 0.544s Queries: 15 (0.003s) Memory: 0.5883 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-06-19 21:47:26 UTCValid HTML 5 and Valid CSS
