Gen1 wiper arm reattachment #989893 03/15/10 01:03 AM
K_Raider Offline OP
I went to Haspin this weekend and lost my wipers. To top it off it rained all day. I took the motor off and found that the linkage just popped off. Cool right? Wrong... I grabbed the linkage to put it back on and it pops off the passenger side. Took the access panel off to put it back on and unless I flashed back to being a 10 year old boy, I cant get my arm in there to reattach it. I had to use hand wipers all day and it sucked. Is there a tip or trick to putting it back on? Im gonna take the wiper motor off and apart to clean it also.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: Gen1 wiper arm reattachment [Re: K_Raider] #989894 03/15/10 03:01 AM
builthatch Offline
hope this helps! alot of gen 1 wiper questions lately <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.4x4wire.com/forums/showflat.p...&PHPSESSID=
'87 swb 5spd 2.6L Montero, >150k miles. Pretty much bone stock as purchased from user ToddStidham1, 'cept some Hella 500's, 700's and Hella ECE headlight conversions.
6'4", 315lbs
Re: Gen1 wiper arm reattachment [Re: K_Raider] #989895 03/15/10 02:48 PM
MarcDurant Offline
Yeah, it's hard. Pull the linkage off of the motor, if you haven't done it already. Then you just have to keep trying. It helps if you have someone else looking through the hole who can tell you when they see the end of the linkage. Might be easier if you remove the hood, too. But basically it's just a lot of fiddling around.
In theory, you can reinstall the driver's side first, which will limit the motion of the linkage and should put the passenger's side in roughly the right place.
If you're removing the wipers on purpose, you can tie a piece of string to the passenger side linkage before you remove it. Then, when it's time to put the linkage back in, you just pull the string.
If all else fails, get a ten year old to help!
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
PHP: 7.4.33 Page Time: 2.096s Queries: 15 (0.005s) Memory: 0.5941 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-04 20:43:04 UTC
