Engine rebuild kits
#990304
03/17/10 05:36 AM
Wheres a good place to find one (engine rebuild kit)thats not up the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> in price and a good kit from a honest place online any one have a good experence latly. Sucks did a compression test,got 180psi on cylinder 1 witch is really good for 160,000 miles cylender 5 150psi below the 10% limit but on grand ol cylinder 3 a wapping 60psi the oil cap smelled like a lawn mower <img src="/forums/images/graemlins/lol.gif" alt="" /> so its seeping past the rings. Didnt even bother checking the drivers side since its a pain in the ass to get to the back ones.Realized i havent posted on here since i think december 1st <img src="/forums/images/graemlins/zombie.gif" alt="" />
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Engine rebuild kits
[Re: 93montero_sr]
#990305
03/17/10 05:46 AM
wow I had 150 on all 6 cyl. guess Im doing alright.
many thanks loren
92 montero rs 3.0 locked rear
[Re: 93montero_sr]
#990306
03/17/10 12:03 PM
so its seeping past the rings. Maybe, maybe not. Squirt a few teaspoons of engine oil through the spark plug hole and recheck. If the pressure remains the same, the problem could be valves, valve guides, cracked head and/or a blown head gasket. And, it's possible that it could be one or more of those in combination with ring wear. #5 cylinder is a favorite place for a 3.0L head gasket to blow. I have seen suggestions that the 2 rear cylinders don't receive adequate coolant flow, but I'm not yet certain that's the reason. Since factory parts are becoming expensive and sometimes scarce, I've been curious to see how cheaply a 3.0L can be rebuilt and still last. For a standard rebuild, I'd be tempted to try one of the auction site kits from a seller who has a good rating, because I suspect that there may be some reasonable value there if you shop carefully. As an example, I bought lash adjusters that normally sell for ~$12/ea for less than $5/ea and expected to get some cheap knockoff - but they were made in Japan and distributed by Sealed Power division of Federal Mogul. They look and perform like the original. I'm not suggesting that is the norm, but that some of the kits may be decent. If you find a good kit at a reasonable price, please let us know. Frank
[Re: FrankR]
#990307
03/17/10 03:25 PM
so its seeping past the rings. #5 cylinder is a favorite place for a 3.0L head gasket to blow. I have seen suggestions that the 2 rear cylinders don't receive adequate coolant flow, but I'm not yet certain that's the reason. cyl. 5 is where mine blew
many thanks loren
[Re: shawnsdad]
#990308
03/19/10 05:18 AM
Hey frank, after i posted earlier i went out to the garage and pour alittle oil down the num 3 cylinder and sure enough it went from 60psi to 65psi and no oil on the plugs so the rules out the valve seal and no water in the oil so its looking like its going to be with the valves maybe a burnt up exhaust valve or seat. I suspected a burnt up exhaust valve since my hydro carbons were barly passing california smog bye 1 at both stages After checking the the primary and secondary ingnition systems they both passed so i'll do a leak down test this weekend to confirm it is indeed something with the valves or something else.
[Re: 93montero_sr]
#990309
03/19/10 10:30 AM
I think you meant it calls attention to the valves. Unless there's a hole in the piston, I'd suspect a burnt valve. It still could be a blown head gasket, though. Either way, it's time to pull the heads and see what's going on. Frank
[Re: FrankR]
#990310
03/20/10 11:20 PM
Yep I got 2 burnt up exhaust valves on the number 3 and 6 cylinders.
[Re: 93montero_sr]
#990311
03/21/10 11:11 AM
You will want to find the cause to avoid having the same thing happen again: web page Frank
