My new t-case skid plate
#990518
03/20/10 02:16 AM
While waiting to find some manual hubs, I decided to fix my stock t-case skid plate and ended up building a new one. My old one was pretty thrashed as you can see. ![[Linked Image]](http://i407.photobucket.com/albums/pp156/epm131/89%20Raider%20v6/100_1942.jpg) ![[Linked Image]](http://i407.photobucket.com/albums/pp156/epm131/89%20Raider%20v6/100_1943.jpg)
Eric 89 Raider V6, 35s, 5sp, welded rear, 8k winch 89 Raider 2.6 going on 84 4runner frame
Re: My new t-case skid plate
[Re: SandRaider]
#990519
03/20/10 02:40 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Looks stout. Could may be use a couple more gussets. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#990520
03/20/10 03:28 AM
Looks good overall. I've thought about what to make if I ever really wheel enough to thrash the stock one. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I have thought something similar to yours, and also with some sides to box it up, and then a drain hole or two for when it splashed up. I would also maybe "top coat" it with undercoating.
[Re: MontyMcV]
#990521
03/20/10 03:52 AM
It's made from 3/16" steel and I added gussets on the on the rear part. I tried to just remake the stock one so I could use the stock bolts/holes, while trying to improve it. It is thicker, has a better approach angle and has about 1/2" extra ground clearance. I didn't spend alot of time on this and I don't really care if it looks pretty, as long as it does it job.
[Re: SandRaider]
#990522
03/20/10 04:44 AM
make me one that is a little better quality on the looks..... and i will pay you for your time and to ship it to me in Cali. mine is dented and bent and the replacement i made bites.
[Re: Guns_and_Roses]
#990523
03/20/10 03:46 PM
Looks good overall. I've thought about what to make if I ever really wheel enough to thrash the stock one. You must have never touched it on a thing. Mine you could bend by stepping on maybe even by hand. My replacement may not have as good of clearnce as the stock one but I can do bigger stuff because I can bang on it without as much fear. ![[Linked Image]](http://pics.montypics.com/tag/2009-05-16/1242483046_dscf0068.jpg)
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#990524
03/20/10 05:13 PM
Looks good overall. I've thought about what to make if I ever really wheel enough to thrash the stock one. You must have never touched it on a thing. Mine you could bend by stepping on maybe even by hand. My replacement may not have as good of clearnce as the stock one but I can do bigger stuff because I can bang on it without as much fear. maybe i have changed my mind and i now want Tag's set up!
[Re: Tag]
#990525
03/20/10 05:29 PM
Here's mine. Since at this point my stock skid on my 89 was a virgin so it was in good shape I re-enforced it. I used leftover stock from another project and it was not quite the right size to get complete coverage, but its way better than stock. One thing I noticed is that the auto T-Case skid is different from the Manual. ![[Linked Image]](http://gallery.me.com/zone1wst/100152/101_2213/web.jpg) ![[Linked Image]](http://gallery.me.com/zone1wst/100152/101_2215/web.jpg)
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#990526
03/22/10 03:11 AM
Heh. Heh. He said VIRGIN!!!
Good stuff Justice! Glad you're home safe <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks for your service <img src="/forums/images/graemlins/patriot.gif" alt="" />
