Page 1 of 3 1 2 3
sunroof??????????? #990640 03/20/10 07:42 PM
shawnsdad Offline OP
I might be getting ahead of my self. but the sunroof was caulked shut. the motor for it works. seems that the gasket was junk. how do i check this? do they still sell the gasket? going to cut the caulk and see what happens. worst that can happen is I got to caulk it back up.....lol
many thanks
loren
92 montero rs 3.0 locked rear
Re: sunroof??????????? [Re: shawnsdad] #990641 03/20/10 09:25 PM
ok so I got it apart. the window is pretty rusty. dont know why it only goes 4" and stops. and I cant find a blown up to see what is all involved in fixing. so will be going to bone yard for that one. found some. 225.00 or less. so im going to caulk back up and wait till I see if im keeping it or not. I probably will since It could be a cool trail rig.
many thanks
loren
Re: sunroof??????????? [Re: shawnsdad] #990642 03/22/10 04:15 PM
MI_Mitsu Offline
The sunroof seals were still available for Gen1 (>91) trucks up until 2 years ago when I last bought mine -still havent replaced it yet btw.
If you need a new sunroof unit, i still have a spare one in the garage, but as you know it is REALLY big and REALLY heavy. The spare sunroof also will need new seals eventually, but if you need parts because yours is rusty, this one will do you real well. No rust from what I recall, just a little dirt.
Send me a PM if itnerested.
Try to get your seals from parts.com or mitsubishiparts.net
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: sunroof??????????? [Re: MI_Mitsu] #990643 03/22/10 05:40 PM
I wish I was closer to you. Im 300 miles away!!lol do you know if there is a blow up of the workings of the sun roof? so I can see what the problem really is.
many thanks
loren
Re: sunroof??????????? [Re: shawnsdad] #990644 03/22/10 07:33 PM
What year is your rig? There are factory service manuals covering most rigs (either very similar or identical model years) on mitsubishilinks.com that you can download for the cost of your connection. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sunroof??????????? [Re: off-roader] #990645 03/22/10 07:38 PM
I'm not sure if this helps but these sunroofs do stop at intervals.
Mine stops about 6 inches open, then stops again about 6 inches from fully open, then finally stops at full open. So there are three intervals of travel.
Again this may have nothing to do with your problem....jsut saying. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: sunroof??????????? [Re: cmonty72] #990646 03/22/10 08:10 PM
mine stops and dont move with ele. motor or by hand crank
many thanks
loren
Re: sunroof??????????? [Re: off-roader] #990647 03/22/10 09:46 PM
wount let me download!!!! do I have to pay
many thanks
loren
Re: sunroof??????????? [Re: shawnsdad] #990648 03/22/10 09:55 PM
No payment required. I was able to download fine. Perhaps your firewall is preventing you from being able to download from it?
Re: sunroof??????????? [Re: off-roader] #990649 03/22/10 10:24 PM
ok it wouldnt let me do the 92 but would let me do the 92-95!!!!! but still didnt get me the detail that I needed. I understand it has cables that run from the front and go to back side. so does the cable push and pull? I guess Im going to have to pull down and look for myself. that should be fun...lol thanks
many thanks
loren
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6380 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-06-18 03:21:01 UTC
