Page 1 of 15 1 2 3 14 15
Monchopo! #990673 03/21/10 03:31 AM
TOASTY Offline OP
[Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
Re: Monchopo! [Re: TOASTY] #990674 03/21/10 03:37 AM
Mitsulvr Offline
Bast...!!! You beat me to it! I stripped the rear out of mine today.
Looks great tho <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: Monchopo! [Re: TOASTY] #990675 03/21/10 03:59 AM
motero Offline
Automatic two inch lift in the rear. Looks cool!
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Monchopo! [Re: TOASTY] #990676 03/21/10 04:00 AM
TOASTY Offline OP
I started out with a '95 Montero that i bought from motero, then got it running and driving. Soon after that i removed the interior then the rear glass. Next was the doors, wiring and the layout for cutting. Chopped it down in sections and changed my mind a bit on what i wanted to do, i was origonally gonna box in the cab with a removable rear window but i decided to just enclose the lower half of the cab up to the window line. The reason i'm going this route is because the LWB B pillar is really narrow and since i'm tall i can't just sheet all the way across otherwise i can't put my seat back far enough. This will actually work out better because i won't have an extra back glass to store. Anyways next I cut the center floor board to be the new lower rear wall and welded it into place, the new center wall will be made from something like a tail gate because i know at some point some will climb in through the back and it will need to be very rigid. I made templates for the steel to box in the 4 corners of the body, the rocker corners will be made out of a thicker plate to prevent colapsing on impact even though i will have sliders. The other thing i did was relocate the roof crossmember, the LWB origonally had 2 body crossmembers and i welded the larger one in at the end of the chop. This should help support the crap i put up on the roof rack and i might even weld the other crossmember in the center just for extra support even though i'm only planning on putting light stuff like sleeping bags and a tent up top. That's all for now i'll keep this updated as i go.
Re: Monchopo! [Re: Mitsulvr] #990677 03/21/10 04:03 AM
TOASTY Offline OP
Mitsulvr, I knew you were serious so i acted quick <img src="/forums/images/graemlins/lol.gif" alt="" />
Motero, I think you're right and your truck has found a good home. I have it's new engine just sitting next to it waiting to go in. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Monchopo! [Re: TOASTY] #990678 03/21/10 04:09 AM
Mitsulvr Offline
Subscribed!
<img src="/forums/images/graemlins/lol.gif" alt="" /> You're lucky I'm sick and cant seem to muster up the energy today.
What's your glass and corners plan? I'm reusing the glass and corners for mine but previous cuts have made the lower sections useless. I have a D50 cab laying around tho. May incorporate that. Sorry Hijack off.
(edit) Fingers and brain not in sync
Re: Monchopo! [Re: Mitsulvr] #990679 03/21/10 04:15 AM
TOASTY Offline OP
The lower rear wall is the old rear floor folded up, the center of my rear wall will possibly be a tailgate so that it will take more abuse plus make the cab more rigid.
Re: Monchopo! [Re: TOASTY] #990680 03/21/10 04:27 AM
Mitsulvr Offline
Sorry I did read that I guess it just didn't sink in. I meant more for the cab corners and back window tho. I reworded my post after I saw what I wrote <img src="/forums/images/graemlins/shiner.gif" alt="" />
I wish I was in AZ to check this out.
Eric Wegerich
Re: Monchopo! [Re: Mitsulvr] #990681 03/21/10 04:32 AM
TOASTY Offline OP
I also put that in there, i made a template for the corners. I'm gonna plasma cut inserts to weld in this week.
Re: Monchopo! [Re: TOASTY] #990682 03/21/10 04:36 AM
Mitsulvr Offline
Wow my reading comprehension sucks today. Sorry about that to many cold meds.
Eric Wegerich
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.6497 MB (Peak: 0.7776 MB) Data Comp: Off Server Time: 2026-07-11 08:04:47 UTC
