blinking 4WD lights #991164 03/24/10 05:42 AM
shawnsdad Offline OP
why when I put it in 4wd or 4wdlock or 4wd low the lights flash on the indacator truck on the dash? something not going in completly? going to look more tomarrow. I put in 4wd H lock. and turned the front tires but didnt notice the front tires jump. so there is something not locking in the front end? any ideas? you guys are awsome!!!!!
many thanks
loren
92 montero rs 3.0 locked rear
Re: blinking 4WD lights [Re: shawnsdad] #991165 03/24/10 05:51 AM
First response: Try using the system more. Sometimes something gets a little "sticky" from non-use/cycling.
Secondly: Has the truck been in a lot of water recently? Mine gets a little wonky after a lot of water crossings or cruising through large mud puddles, but it clears up after it dries out.
Somewhere on here, there is a link to a big write-up on how the system works, and it's surprisingly complicated, but the article takes you through the how's and why's before getting into a step-by-step diagnostic. Does anyone know where to find it (obviously, I type before I look)?
Re: blinking 4WD lights [Re: JohnnyBfromPeoria] #991166 03/24/10 05:59 AM
been sitting for a year. and who knows befor that. going to keep switching to 4wd and cycleing it. does that mean that its not locking in the front axle? or the hubs? or both. in lock the rear does lock and the blinking stops on the rear end in panel.
many thanks
loren
Re: blinking 4WD lights [Re: shawnsdad] #991167 03/24/10 06:41 AM
Who knows what it's really doing without further diagnostics. I'm betting that it's more of a sensor problem than anything. These things are built right, so I'd suspect minor problems first.
Where in IL are you? You can probably guess where I'm from...
Re: blinking 4WD lights [Re: shawnsdad] #991168 03/24/10 03:06 PM
WigWiggy Offline
Two great links for this:
Mostly electrical troubleshooting and
Mostly Mechanical troubleshooting
Note that on the second writeup, he's working with a right-hand drive model, so when he says "driver's side" he means our passenger side.
98 Montero, 184k.
Re: blinking 4WD lights [Re: JohnnyBfromPeoria] #991169 03/24/10 03:18 PM
crystal lake il.
many thanks
loren
Re: blinking 4WD lights [Re: shawnsdad] #991170 03/24/10 08:08 PM
Was the engine running? The system uses engine vacuum to move the front axle disconnect and engage the fwd. Sometimes weak vac won't do it, and you have to rev it and snap the throttle shut to get it loosened up and working...
Re: blinking 4WD lights [Re: fasteddy] #991171 03/24/10 08:29 PM
got it working. just needed to work it. the vac. lines are really oil saturated so Im going to change them. i think im losing vac. through the lines. now the rear locker and the transfer case in lock mode are the only thing blinking. probly just needs to be worked also.
many thanks
loren
PHP: 7.4.33 Page Time: 3.531s Queries: 15 (0.004s) Memory: 0.6231 MB (Peak: 0.7183 MB) Data Comp: Off Server Time: 2026-06-23 11:29:38 UTC
