Used FWD 6G72 SOHC from Japan to 1993 Montero
#991219
03/24/10 11:37 PM
I need to replace my 12V motor and found a shop that has a used 6G72 long block from Japan that's from a sedan. I know I have to swap out the external components and brackets, should I also swap the fuel injectors?
Are there any issues doing this type of swap?
Re: Used FWD 6G72 SOHC from Japan to 1993 Montero
[Re: cyborg_89]
#991220
03/25/10 12:20 AM
IIRC most sedan motors are transversely mounted. That also means the dipstick was on the wrong side.
I also believe the cams are for a different kind of torque curve than the montero setup but it should still work.
As for the rest, I'm sure there are probably other differences but I know others will be way more knowledgeable than I will on that info.
Welcome to the wire! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#991221
03/25/10 02:57 AM
Hmm, too bad I didn't see this thread before responding to the other one...
[Re: MontyMcV]
#991222
03/25/10 03:38 AM
A sonata will work but a Diamante 3.0 12v SOHC has different cams and pistons...
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: MontyMcV]
#991223
03/25/10 04:33 AM
I thought the first post didn't go through. I deleted it. Thanks.
[Re: cyborg_89]
#991224
03/25/10 05:39 AM
Most any of the AA or AJ body Mopars (Chrysler LeBaron Convertible, Coupe, Sedan; Dodge Spirit; Plymouth Acclaim), as well as select Dynastys, New Yorkers, and Dusters, will have a 3.0 option: Same motor as the Monty/Raider 3.0, but with the exceptions noted by others (different cams, oil dipstick, etc.). The Mopar version of the motor came with power steering as standard, so a single belt wraps that with the rest. A/C was optional, so that has it's own belt, like the Montys.
It wouldn't surprise me if your oil pan was a straight swap to put the dipstick on the "proper" side, but with the space under the Monty hood, it shouldn't matter left or right.
Interesting tidbit: I'm under the impression that the 6G72 was conceived and designed as a FWD, right-side facing, right-hand drive motor. This would put the power steering pump on the right-hand side near the steering, and the A/C compressor near the front and the condenser.
When the same engine is turned to face forward, with left-hand drive, the power steering has to cross to the left side of the vehicle, while the A/C has to cross over to the right side.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
[Re: cyborg_89]
#991225
03/25/10 02:50 PM
I thought the first post didn't go through. I deleted it. Thanks. Cool. There have been new members in the past who have posted up multiple threads when they didn't get a fast response. Sorry if I sounded snippy... <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: KrzyDav]
#991226
03/25/10 03:46 PM
Obviously there are a lot of people on here that know about 50000 times what I do but I did put one of these "Japanese swappers" on my 95 3.5, every external bracket and component: not that bad. NOT KNOWING TO CHANGE VALVE GUIDE SEALS THAT HAVE BEEN STORED DRY FOR MORE THAN 1 YEAR: VERRRRRRY BADDDDDDDD. The job would have been easy before I nestled that mass of aluminum under the hood, too bad I didn't know then to also do the VLAs when I did the seals.... Just a thought.
95 SR + 94 SR Might =1 SR.
