Page 1 of 4 1 2 3 4
you guys are awsome!!!!! another couple questions #991232 03/25/10 02:09 AM
shawnsdad Offline OP
it has A/C but compressor was removed. going to look for one. the lines are there but cant find the power wire hook up any where. where does the wire come out from? there are 4 sensors by the thermostat. a/c, temp gauge,and another that looks just like the temp gauge. says for A/T. ok what is the one for the A/T? and again you guys are awsome. Im learning so much and enjoying it.. thanks again!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
many thanks
loren
92 montero rs 3.0 locked rear
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991233 03/25/10 03:20 AM
You should have a temp switch for the a/c (turns a/c off on overheat), a temp switch for the a/t (diables o/d when engine is cold), a temp gauge sender (fat single wire), and a temp sender for the fuel injection ecu (two wire with connectors in a tee shape).
Re: you guys are awsome!!!!! another couple questions [Re: fasteddy] #991234 03/25/10 03:25 AM
ok kool. this thing just isent idleing very good and just looking and looking to figure it out. thanks again
many thanks
loren
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991235 03/25/10 04:08 AM
Slow, fast, or rough? Rough (usually rich with a gassy smell from the exhaust) is a bad ecu temp sensor, mostly. Could also be a bad adjustment on the throttle position sensor. Slow or fast, usually slow, is a bad idle control unit, under/behind the TB. This assumes new plugs and good wires. NGK's are the best plugs, and nearly the best wires in my book.
Re: you guys are awsome!!!!! another couple questions [Re: fasteddy] #991236 03/25/10 04:44 AM
700 rpm rough idle. when cold really rough when warm its better. reason to me is its hotter to burn the gas. ordered a new 02 sensor. it looks org. lots of black smoke when cold. (rich) new plugs cap rotor wires. I change them after replacing head gasket. ran changed again and they were black with soot!!!! really rich.
many thanks
loren
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991237 03/25/10 05:23 AM
I am trying to figure out where the ele. hook up for the A/C compressor is. where does the plug come out by? where can I tap into ti remake a wire hook up. all the picks I can find shows the wire. but not where it comes from.... really ticking me off!!!lol why do some people that think they know what they are doing do things that they have no clue??? <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
many thanks
loren
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991238 03/25/10 05:44 AM
mxmikie Offline
iac motor
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991239 03/25/10 05:45 AM
W
WagonMaster Offline
If you don't already have an A/C unit, I believe any 3.0 AA or AJ body MOPAR (Chrysler LeBaron, Dodge Sprit, Plymouth Acclaim) uses the same compressor.
Interestingly, a mid-90's Honda Accord (IIRC) uses the same compressor, but spinning counter-clockwise.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: you guys are awsome!!!!! another couple questions [Re: mxmikie] #991240 03/25/10 06:14 AM
is there a test to check it? 110.00 dont want to spend it if its not it...
many thanks
loren
Re: you guys are awsome!!!!! another couple questions [Re: shawnsdad] #991241 03/25/10 06:31 AM
Loren, would you PLEASE go to 'My Home' at the top of the page and edit in a signature that includes your year and model? You'll streamline things that way, 'cause we can't all remember what you drive.
And for the record, MxMikie is the King of Short Answers. Apparently not much into details, that guy, although he seems to know what he is talking about. See what comes up doing a search under IAC in the Mitsu Tech Section, resetting the time frame to say, five years.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6397 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-06-21 20:34:14 UTC
