Re: you guys are awsome!!!!! another couple questions
[Re: shawnsdad]
#991252
03/27/10 05:32 AM
ok I did find it. it says to hook up a special wire harness to check. can I just find the color wires off the org. plug? or do I need something special? going to try in the morning.
many thanks loren
92 montero rs 3.0 locked rear
[Re: shawnsdad]
#991253
03/27/10 05:55 AM
See Pg 13A-96. The explanation on how to check it using a 'Special Took' (aka a standard multimeter) is there.
[Re: off-roader]
#991254
03/27/10 02:12 PM
many thanks loren
[Re: shawnsdad]
#991255
03/28/10 12:27 AM
did the test on the IAC and a question. when you touch the circuit and it vibrates it is supposed to keep shaking or just a quick shake? because if it just shakes a little im good if not need a new one. it passed the ohm test for the coil.
many thanks loren
[Re: shawnsdad]
#991256
03/28/10 01:04 PM
I have a 1992 FSM. Last sentence of test procedure says: "If, as a result of this test, vibration is felt, the stepper motor can be considered to be normal."
Is that what you need to know? There is a 6 step check process for troubleshooting IAC after it is removed. Is that what you are following?
[Re: pcc]
#991257
03/28/10 02:58 PM
thats what I am folowing. but is it a very short vibration or does it stay vibrating??? it shakes for less than a sec. I would have thought it would stay shaking.
many thanks loren
[Re: shawnsdad]
#991258
03/28/10 03:10 PM
Did you do the test for each terminal using 6v power source? My backup Haynes says; "If servo vibrates slightly during these tests, it's OK. If not replace." "...note whether there's any vibration..."
I've never done the test but it looks like a short (slight) vibration is a pass. Did you test TPS?
[Re: pcc]
#991259
03/28/10 03:53 PM
yes. I taped 4 aa batteries together. and some times felt the shake. going to test again. yes it passed but they are so short bursts of shaking Im going to make sure. I thought it was supposted to move in and out also? didnt test the tps. will do in a couple minutes.
many thanks loren
[Re: shawnsdad]
#991260
03/28/10 04:29 PM
has anybody ever done this its a PITA!! lol Iv done it several times. I not happy with how it shakes more on some then others. and now it is failing the test!!!!! Im just going to get a new one and if thats not it. well at least I know. going to test everything under the hood. next is tps. then purge valve. Its just a extra car that I can just tinker with. Im in no rush. and since Im not working I have lots of time on my hands...lol
many thanks loren
[Re: shawnsdad]
#991261
03/28/10 04:36 PM
Im just going to get a new one... Just have yours rebuild. Lots less $$ <img src="/forums/images/graemlins/kewl.gif" alt="" />
