Rating: 1
Page 8 of 52 1 2 … 6 7 8 9 10 … 51 52
Re: suzi the psychic [Re: rascott] #991499 03/05/11 12:49 AM
rascott Offline OP
i suppose this kind of mounting the adi ar-446 is as easy as anything.
typical lazy man.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #991500 03/05/11 02:16 AM
Richard, not an overhead mount for so many radios?
Re: suzi the psychic [Re: rascott] #991501 03/11/11 04:02 AM
rascott Offline OP
it is looking like work is going to interfere with me leaving town.
my next opportunity to run won't be until april(mid).
i think that will be better for my original "planning" anyway.
i have the time for some more little changes before then.
i have another antenna showing up any day that i can mount and tune, a cb radio to change out, and some channel iron that could help me get the rest of the body lift i wanted
way back when.
suzi could show some more leg soon.
i have pulled the rear bumper off to access the rear mount points(body studs) and you can see how i gained 1 1/8" of lift before.
i took out the headlight assemblies for the front mounts(bolts-easy).
this is what the mid body mounts look like(body studs).
i am disconnecting stuff to be able to lift the body off the chassis, like the gas fill thing....
i think i can.
i wanted a 2" body lift.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991502 03/11/11 05:01 AM
suzi with Stilettos? Cool.
Re: suzi the psychic [Re: rxinhed] #991503 03/12/11 01:33 AM
rascott Offline OP
yeah- she will really be strutting her stuff if i can pull this off.
i have ignored a little tire rubbing here and there. this will help.
i don't want to have to monkey with extending shifters and stuff, but think another inch up wouldn't be too much.
re:radio mounting.
zip ties are probably too easy. not very "professional", though.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991504 03/13/11 02:31 AM
rascott Offline OP
i finished separating the body from the chassis and examined the situation for a while.
with my primitive fabricating tools, i made up some "blocks" out of 3x1 1/2" channel iron.
this would mabe fit the front or rear.
if i weld it here(rear).
or here(front).
the side ones will look like this.
with the bushings arranged like this i figure a 2 1/2" lift from stock.
i need to see if i have interference anywhere before i prep the parts for welding.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991505 03/13/11 06:07 AM
Oyaji_Jon Offline
Hi Richard,
I see what you're trying to do and it looks like it would work. Just a thought, but I have access to a great metal supply down here near me, and I can run out there to see if I can get a scrap piece of round stock next week. If you give me the diameter of your bushing, I can get a piece that is just bigger for you to put in there. I can probably get them to cut it to your desired thickness, as well. I go there for all my materials, so they always help me on the cheap. Once I get them home, I can chock them up in the drill press and bore the holes you need for the bolts and bring them up on a soccer day.
Give me a call, if you'd like, and we can figure out what you need.
Jon
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: suzi the psychic [Re: Oyaji_Jon] #991506 03/13/11 10:41 PM
rascott Offline OP
thanks for that, jon.
i already got it half done(at least the welding), and have been ok with the chunks of belt material i was using before.
i think this will work.
i will have to modify the rear bumper. i was able to get away with it last time, but another inch+ makes it look bad.
i may have to modify the holes the gear shifters stick thru.
seem to have less room for 2nd, 4th, and reverse gears.
update: finished setting and welding(that's what i call it) the blocks. i still need to modify 4 support pads before i fasten the body back on, but it's sitting in place.
it started raining.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991507 03/14/11 06:15 AM
Oyaji_Jon Offline
Good stuff, Richard. I'm glad it's moving along!
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: suzi the psychic *DELETED* [Re: Oyaji_Jon] #991508 03/16/11 03:50 AM
Post deleted by rxinhed
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.095s Queries: 15 (0.091s) Memory: 0.6567 MB (Peak: 0.7676 MB) Data Comp: Off Server Time: 2026-10-24 01:25:26 UTC
