Rating: 1
Page 20 of 52 1 2 … 18 19 20 21 22 … 51 52
Re: suzi the psychic [Re: rxinhed] #991619 04/08/13 08:21 AM
rascott Offline OP
there are advantages to a kit, but i can't spent that kind of cash on poor little suzi. i kinda figured i'd scavenge the whole front off a sammy, then figure a way to make whatever frame extension pieces, spring mounts, steering whatevers and i don't know whats.
there are some others making parts for the swap(toy axles seem popular also) that i might approach first. i'm not too sure @ calmini....i've heard complaints. their stuff looks good though.
i don't think anything 's happening too soon.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #991620 04/15/13 12:42 AM
rascott Offline OP
i'm still slowly constructing some sort of skid plates under suzi the psychic, and am beginning to do more than lay on my back and stare at it.
i added some mount points on the chassis, for the transmission plate.
it may make sense later. it may work.
picad041913
mabe braces.
i will try to get some better pics-
babalon042015
it should look something like this under the transmission when it's finished...
gressad042113
added some more weight under the transfercase.
got stuck when i broke a tap off in one of the added mount points.
that's it for this weekend.....
Re: suzi the psychic [Re: rascott] #991621 04/15/13 02:20 AM
Will you be making a belly pan?
Re: suzi the psychic [Re: rxinhed] #991622 04/15/13 06:31 AM
rascott Offline OP
sort of- i had fashioned a skid plate to protect the oil pan and front differential. now i'm working on a plate for the transmission area, plus one to cover the transfercase.
i have some ideas to protect the side body mount and trailing arm brackets. i've been finding large rocks on my travels.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991623 04/27/13 11:31 PM
rascott Offline OP
i finally recycled my $5 yardsale special one functional wheel 6" benchtop grinder. now have a hf 8" that is sooo much more useful' i feel empowered to continue.
i also got a new tap and a real tap handle.
figured out some bracein'(and cut the plate) for the transfer case.
"armored" the trailing link mount, added some brackets along the chassis, and fixed-up the front/side body mount, glueing it on with 50# of welding slag.
if i stick this piece on those brackets, it might get hit by rocks, but may stay on.
Re: suzi the psychic [Re: rascott] #991624 04/29/13 01:01 AM
Might you also be planning supports for an overhead rack via verticals from the sliders?
Re: suzi the psychic [Re: rxinhed] #991625 04/29/13 03:57 PM
rascott Offline OP
nah- i'm sure a roof rack would encourage overloading, and i carry way too much stuff as it is.
i should look in the bottom layers and see what i can chuck out and not miss.............
suzi the psychic has the little motor.
getting your leisure time figured out? can't beat the weather we've been having...makes work less interesting- i keep thinking i should be someplace else...
i am running 05/09-0513. probably ef carson(if my brother is able) or french meadows/hellhole(if he's not).
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991626 04/30/13 01:33 AM
rascott Offline OP
the driver's side slider thing was easier to do than the other side.
it shouldn't fall off, and may fend off a rock or two.
now i now plan to finish the skid plate project.
looking like french meadows/hellhole area for next window- busy brother.......
update050513
finished the skid /rock guard project.
i have 3 days to unpack/sort/repack......
haha05091303:31
dropped a lugnut as i was changing a wheel. into a gopher hole. perfect shot. went in about a foot, and around a corner. made a big hole next to my driveway and recovered it. interesting tunnel systems those creatures construct.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991627 05/13/13 09:03 PM
rascott Offline OP
suzi the psychic and i did some exploratory pokings around the loon lake, hellhole, and french meadows reservoirs.
i found the loon lake to rubicon connector challenging.
i decided not to throw myself at the little sluice box.
camped at loon, wentwoth springs, and talbot(mf american).
mo'pic0521
tried to get to soda springs(hwy80) from french meadows, but finally found some real snow......
took a different tack to come out in auburn. nice drive.
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991628 06/02/13 06:43 AM
rascott Offline OP
i kinda beat-up little suzi the psychic a bit this last run, when we went to look at the rubicon. hit the exhaust some, but it's still functional, blew a bead on one of my fronts that didn't re-seat completely, and bent the left trailing arm again.
i modified a spare left side arm by welding some angle iron to it and moving the brake cable bracket.
mabe it'll be stronger.
i expect to try it out in july.
gonna try the rubicon again.
i also munched up my front skid plate, and may see if i can straighten and stiffen it before i go......
mabe the gas tank is a bit vunerable- the stock skid is more of a skin plate....
adpic060213
the 2nd bent one.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 7.928s Queries: 16 (0.014s) Memory: 0.6633 MB (Peak: 0.7941 MB) Data Comp: Off Server Time: 2026-11-15 09:59:59 UTC
