Rating: 1
Page 27 of 52 1 2 … 25 26 27 28 29 … 51 52
Re: suzi the psychic [Re: rascott] #991689 05/02/15 06:06 AM
rascott Offline OP
suzi is gonna get her front end tickled a little bit.
got her some replacement spindles.
i expect to take some slop out of the front wheels.
she wants to go play, but must be patient.
circumstances force a later start to the season.
i'll add to this.....
the lotus project is well underway, and lots of fun.
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: suzi the psychic [Re: rascott] #991690 05/03/15 12:35 AM
Lotus? A 7, Esprit, Cortina?? Inquiring mind wants to know...
Re: suzi the psychic [Re: rxinhed] #991691 05/03/15 02:18 AM
rascott Offline OP
europa. 1969 s2.
hope to road test in a couple of months..........
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991692 05/03/15 06:40 AM
We'll need pics!
Re: suzi the psychic [Re: rxinhed] #991693 05/10/15 08:05 PM
rascott Offline OP
We'll need pics!
this is as today.
just put "the lotus" back on the ground, after 6mo. on blocks, for some systems check.
mabe i should put the steering wheel back in- wanna move it around a bit, if all goes well.
rescue- not restoration. i've been making a lot of parts....
and something is wrong with my picture thingy(?).
attachment? works when i click it, but only one pick....?
Re: suzi the psychic [Re: rascott] #991694 05/10/15 08:14 PM
rascott Offline OP
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991695 05/11/15 04:32 AM
Looks good. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: suzi the psychic [Re: rxinhed] #991696 05/11/15 06:54 AM
rascott Offline OP
thank you, oh photo wizard.
why couldn't i do that?
some intentional.
kj6esv
Re: suzi the psychic [Re: rascott] #991697 05/12/15 03:26 AM
You did, actually. The text from your photo:
http://www.4x4wire.com/forums/post-images/1298510-002%281024x577%29%282%29.jpg
I plucked the URL text and added it into the image link.
Re: suzi the psychic [Re: rascott] #991698 06/10/15 11:56 PM
rascott Offline OP
hmmm.
suzi the psychic has slightly wobbly front wheels, as if the wheel bearings were loose.
a bit back, i'd pulled the hubs off and replaced the bearings(and seals), thinking that would fix it.
nooooo(as in no difference at all).
my next theory was that the spindle must have been worn, 'cause the bearing had been dirty, rusty, with a nice grinding paste for grease, and did have some obvious wear spoor.
so i picked up some knuckle out chunks from a wrecker, took the spindle out of one, and swapped out the right side.
this has made no difference at all.
instead of doing the same to the other side, i will put the wheel back on and think about it.
hmmmm......
afterthink061015
go figure.
couldn't give up.
looked at my parts, swapped hubs(kept races and outer bearing from donor), used newer seals, and newer inner bearing.
this combination seems to work.
hmmmm.......
mabe i should try some similar combo on the other side.
not sure i understand, but....... o k.
whonos061315
left side, clyde.
used donor spindle, hub and bearings, newer seals.
just fine. go figure.
i see no significant difference in the parts.......
gonna finally make a run next weekend(4day) to the e f carson, to see if there is any water left.
i will add a picor2 of a proper rear diff. spacer to perk up suzi's ass a bit- replacing a few poor attempts at making one.
l8tr.....
something is wrong w/my picposter.....
oh, and that's my last setup- the thing was not strong enough- had it fail once.
brpmor061515
upndown the street, suzi seems ready to go play.
trying a new chuckwagon thing, this time, thrown together for function trial.
i'd show you a picture, but that has been a bit aggravating lately......
need to consider that url stuff- don't like the photobucket way.
tripdelay061715
ran suzi to work this morning, and the clutch cable started coming apart- one big "grink" and suzi suddenly had some freeplay in the pedal, and the clutch would barely disengage.
got her home(after work) and pulled the cable.
3 strands left. hahaha
replaced with her spare, after fashioning a stiffening plate to compensate for the firewall failure where the cable housing fits.
now i can finish packing. want to pick up my brother and miss bitchy in the morning. and leo.
that's about 6hrs away, for me.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.028s Queries: 18 (0.025s) Memory: 0.6582 MB (Peak: 0.7815 MB) Data Comp: Off Server Time: 2026-10-22 00:09:50 UTC
