Page 2 of 3 1 2 3
Re: OK running great at running temp but crappy cold [Re: fasteddy] #992161 04/01/10 12:30 AM
shawnsdad Offline OP
lol!!!!!!!!!! thanks
many thanks
loren
92 montero rs 3.0 locked rear
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992162 04/04/10 03:13 AM
ok no codes!!! the volt meter just bounces so now where do I go?
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992163 04/04/10 04:27 PM
As dumb as it sounds, my plugs have something to do with this. I change plugs and it starts and runs fine for around 500 miles. Then I have it running after 500 miles and it is cold and choppy in the morning. My 2 cents.
Re: OK running great at running temp but crappy cold [Re: Mudraider] #992164 04/04/10 11:41 PM
try reading the codes with a cheap 12v test light. Long blinks are the first number in the two digit code, short blinks are the second number. For example, long blink, long blink, short blink is 21. Some voltmeters (like a good digital or an undamped cheapie) bounce too much to get a good reading. The light works better.
Also check the accordion hose for any leaks. Air leaks there bypass the mass air sensor, and can lean out the mixture enough to make it run bad cold. Check the hose to the valve cover off the accordion hose, too, for leakies.
Re: OK running great at running temp but crappy cold [Re: fasteddy] #992165 04/05/10 12:36 AM
Oyaji_Jon Offline
Your problem sounds a lot like the one I fought for a LONG time. It turned out I had two vacuum lines backwards.
When the engine is cold, start it up and go to the EGR valve. Pull on the diaphragm and see if it acts any differently. If it does, you have a vacuum line on wrong somewhere. Mine turned out to be on the back of the intake plenum. If you look at the vacuum hose diagram, you'll see two fittings up there. Once I corrected the vacuum connections, it immediately started running correctly and passed CA smog the first time with flying colors. I promise you that it's the simple things that get you, and you don't want to know how much time/trouble that little vacuum hose cost me.
EDIT: Here is the quote from my thread on the old Black Raider I had.
Just a quick note to say that I found the reason this damn thing has been giving me fits at cold idle while waiting for the oil to drain. I had the #@%@$%^&#$%^#@% fuel pressure regulator going to the thermo valve instead of the plenum. switched the two vacuum lines, and badda-boom, runs like a CHAMP! ^@^&&#$%@#%#%...
Anyway, I'll be fuel economy increases drastically now, too. Hopefully, I didn't kill the cat or carbon up the system during my bout with stupidity. Off to get a smog check I go. I think I'll let them do a "pre-test" first. I don't need Sacramento to see this thing as a POS with the possibility of a CA buyer...
HTH
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OK running great at running temp but crappy cold [Re: Oyaji_Jon] #992166 04/05/10 01:38 AM
I dont have a egr valve. and if I do I cant find it!!!!! lol
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992167 04/05/10 04:47 PM
test light shows nothing. never lit up!!! so I guess theres not a problem....
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992168 04/05/10 04:57 PM
hazy_daze Offline
That's not good methinks. You may want to find another computer to test with.
Re: OK running great at running temp but crappy cold [Re: hazy_daze] #992169 04/05/10 04:59 PM
the ohm meter just bounced. test light didnt light up. whats next?
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: hazy_daze] #992170 04/05/10 05:02 PM
I also have a otc scanner. when hooked up. it shows no code. also reads no data... ecm?
many thanks
loren
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6380 MB (Peak: 0.7464 MB) Data Comp: Off Server Time: 2026-06-21 01:28:47 UTC
