Page 3 of 3 1 2 3
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992171 04/05/10 06:07 PM
On a 92 with the 12v v6, there are two diagnostic connectors under the driver's dash, left side. One (the left one) has offset rounded ends, and the right one has square ends. Connect the light/voltmeter to either of the top center connections on the rounded end connector (grounds) and to the upper leftmost connector on the square end connector, and switch on the ignition. The codes should be output, if any.
Re: OK running great at running temp but crappy cold [Re: fasteddy] #992172 04/05/10 06:45 PM
shawnsdad Offline OP
nope only find 1 its the sq one hanging on the right side of the fuse panel. where would the other be? I have the panel off under the steering to see better but still cant see it.
many thanks
loren
92 montero rs 3.0 locked rear
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992173 04/05/10 07:11 PM
Oyaji_Jon Offline
I dont have a egr valve. and if I do I cant find it!!!!! lol
Sorry, I didn't realize you had a 92. Was that in your signature before? <img src="/forums/images/graemlins/shiner.gif" alt="" />
I'll crawl back in my hole now...
Good luck.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OK running great at running temp but crappy cold [Re: Oyaji_Jon] #992174 04/05/10 09:12 PM
Hmmm. My 92-95 manual says they are on the footwell sidewall, just above the bottom edge of the dash, but the hand drawn diagrams aren't all that clear. If you have a diagnostic connector behind the glove box, the two terminals are upper right and lower left, catch at the top.
Re: OK running great at running temp but crappy cold [Re: fasteddy] #992175 04/05/10 10:49 PM
behind the glove box I see one plugged to a black box above the hvac stuff is that the plug we are searching for?
latch side XX XX
other side XXXXXX
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992176 04/05/10 11:05 PM
nope that wasnt it!!!!
many thanks
loren
Re: OK running great at running temp but crappy cold [Re: shawnsdad] #992177 04/05/10 11:44 PM
ISC? isent that the IAC what you are talking. to the left of below the bore. using a drill bit? I dont remember reading the. a feeler gage and set the tps to the point of continunity. where is the drill bit used? I have a otc scanner it has no codes. I go to try to use the diagnostic and it shows nothing. and I dont know why!!! but still reads no codes.
Not clear what you mean in the first few sentences. But regardless it's not clear if you've actually checked the ISC (aka IAC) yet.
If you haven't, you should. It functions as a choke when the engine is cold and if it's not working properly your engine will run like crap until it warms up.
The Factory Service Manual has the procedure to test it (you have downloaded that right?) All you need is an ohm meter / multimeter for the test. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OK running great at running temp but crappy cold [Re: off-roader] #992178 04/06/10 12:30 AM
yes I checked it. it passed. bought one from bone yard and does the same thing. runs like crap till warm
many thanks
loren
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6331 MB (Peak: 0.7281 MB) Data Comp: Off Server Time: 2026-06-21 19:00:14 UTC
