Searched the forum to no avail, so another question for ya #992220 03/30/10 11:39 PM
Rafterman191 Offline OP
Are there any other non mitsu wheels that will fit the factory axles (6 bolt) on a '91 rs? Hope that makes sense. Thanks guys.
'91 Montero RS
'96 Sidekick JLX
'78 Wifey XXX
let me tell you of the days of high adventure...
Re: Searched the forum to no avail, so another question for ya [Re: Rafterman191] #992221 03/31/10 12:13 AM
6x5.5" bolt pattern. Same bolt pattern as some chevy's and some toyota's.
Center bore needs to be big though.
When you say other rims do you mean OEM rims or aftermarket?
Re: Searched the forum to no avail, so another question for ya [Re: off-roader] #992222 03/31/10 12:21 AM
I suppose either, I was just trying to expand my options, and it looks like I can <img src="/forums/images/graemlins/kewl.gif" alt="" />
ETA: How wide can I go with a rim without modifying?
'91 Montero RS
'96 Sidekick JLX
'78 Wifey XXX
Re: Searched the forum to no avail, so another question for ya [Re: Rafterman191] #992223 03/31/10 12:59 AM
Well the rim width alone isn't a problem. The offset and tire width are far greater issues when going wide.
I run 33x12.5x15 tires on 15x8 rims with a neutral offset without issues on my gen I v6 and 35x12.5x15 tires on 15x10 rims with 4" of backspacking without issues on my 96SR. In both cases I do have a 2" body lift and torqued torsion bars. On my gen I, I also have gen II rear coils which also provides some additional lift.
How wide do you intend to go?
Re: Searched the forum to no avail, so another question for ya [Re: Rafterman191] #992224 03/31/10 02:27 AM
some early chevy with the big hub hole, some toyota 4wd, most anything with 6 on 5.5" with at least a 4 1/8" center hole...
Re: Searched the forum to no avail, so another question for ya [Re: fasteddy] #992225 03/31/10 02:52 AM
0778drz110 Offline
chevy
nissan
isuzu
toyota
mitsubishi
all have some form of 6x5.5" the hole might not fit over the hub though, always check before you buy <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Searched the forum to no avail, so another question for ya [Re: 0778drz110] #992226 03/31/10 03:46 AM
Pete_D Offline
I checked into this when I was looking for wheels. After going and checking on quite a number of possibilities I ended up with some SR wheels. Some of the wheels that fit lug wise do not let you have enough center bore. Others are not offset enough and lessen your track + limit your tire options due to clearance. Others I looked at just seemed flimsy.
I also thought about wheel spacers for some of the non offset wheels but decided against it wanting the load sharing on bearings/axles to be as close to OE as possible. If I remember right Ray had a nice sketch made out about wheels and offset versus needs.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Searched the forum to no avail, so another question for ya [Re: Pete_D] #992227 03/31/10 04:14 AM
I did check that diagram out, took a second to make sense of it, but figured it out. Great help all, thanks! <img src="/forums/images/graemlins/patriot.gif" alt="" />
'91 Montero RS
'96 Sidekick JLX
'78 Wifey XXX
Re: Searched the forum to no avail, so another question for ya [Re: Rafterman191] #992228 03/31/10 04:57 AM
RigilKent Offline
as far as wheel size were you refering to diameter or width. I would say that you dont need to go any bigger than a 16in diameter. and width has a lot to do with the offset.
84' Montero 2.6L SWB
Re: Searched the forum to no avail, so another question for ya [Re: RigilKent] #992229 03/31/10 06:25 AM
Nissan, Isuzu, GM 1/2T, and AMC 6-lug OEM wheels will not have a large enough hub diameter. I have not mounted up Mazda wheels, so I have no comment for them. Most of the aftermarket steel wheels that I've come across ago on fine. I have mounted up Toyota steel wheels from the 80s trucks with no problem, but they are only 6" wide. I've mounted up late model Tacoma 16" alloys but found the backspacing too much for my preference, then sold them for profit. I really liked the Isuzu Amigo wheels, no go on the front hubs without machining. Find some old Enkei or US wheels, or a narrower tire like a 33x10.5. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6409 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-06-24 00:14:10 UTC
