I did a 3 pt turn and REEEEEK from the front end
#992355
04/01/10 03:34 AM
Seemed like it was the outside wheel making the noise. I got 31 10.50 15's on stock rims. Is that a normal noise for a hard, slow turn. I am driving the family to Lake Monroe, IN next week and gonna haul about a 14ft pop up trailer. What should my checklist be (I only have tomorrow to do it). Tires are new, I got a decent enough spare. Oil and tranny fluid looked clean enough.
'91 Montero RS '96 Sidekick JLX '78 Wifey XXX
let me tell you of the days of high adventure...
Re: I did a 3 pt turn and REEEEEK from the front end
[Re: Rafterman191]
#992356
04/01/10 04:04 AM
grease your steering stops.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#992357
04/01/10 04:32 AM
check your muffler bearings <img src="/forums/images/graemlins/kewl.gif" alt="" />
steering stops grinding, nothin to worry about <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Rafterman191]
#992358
04/01/10 04:56 AM
Might be a loose power steering belt, that will only squeak at high pressure (like full turn) now, but will get worse over time. Just test belt deflection, then spray some WD-40 on the belt. That will give it extra grip. If the squeaking stops, tighten the belt.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
[Re: WagonMaster]
#992359
04/01/10 05:10 AM
[Re: PHIL_]
#992360
04/01/10 06:38 AM
