Page 2 of 3 1 2 3
Re: Coil Spring airbags [Re: 89montero] #992746 04/07/10 03:31 AM
bretwalda Offline
Don't get longer than recommended. Augie had longer ones and that just made problems for the coil staying set. The bags add rigidity/lift from the walls of the bag anyway - not the top/bottom. The Gen2's are shorter but the spring rate is higher - go with what AirLift recommends.
concreteprinter.com
Re: Coil Spring airbags [Re: bretwalda] #992747 04/07/10 04:59 AM
PHIL_ Offline
I can't find my part number right now... but I did order the normal height set. They came with a spacer (instructions said it was for the Cherokee (?) application, which used the same bag ...think it was a Cherokee?). I used the spacer, which was just the ticket with my coil spacer.
Re: Coil Spring airbags [Re: PHIL_] #992748 04/07/10 11:11 AM
Mad_Scientist Offline
I didn't bother with the spacer. Just stuffed them in the coils <img src="/forums/images/graemlins/lol.gif" alt="" /> I also added a 1/4" ball valve between the bags so I could have air transferring from one side to the other when off road. However, these days I leave them empty until I need them for carrying a load. My truck, like so many on here, is used for many different things <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Coil Spring airbags [Re: PHIL_] #992749 04/07/10 03:03 PM
sasnydley Offline
I put mine in with the Spacer that was for some other vehicle??? That was a couple yrs ago..
Re: Coil Spring airbags [Re: sasnydley] #992750 04/07/10 07:18 PM
sparkem Offline
I had bags in my Raider, I liked them. I have gen2 coils in my black Gen1 now. I like those better. I have valley coils and bags on my Gen2. I like the gen1 with gen2 springs better. If I carried a lot of stuff a lot I would put bags in the gen1.
Re: Coil Spring airbags [Re: sparkem] #992751 04/07/10 09:36 PM
89montero Offline OP
I usually have at least 80lbs of stuff in the back anyway and I can easily have over 200 if I'm actually hauling things plus I do tow fairly often and just hate it because it's always practically sitting on the bumpstop.
The reason I was looking at the slightly longer ones was because not only do I want to get it back up to stock height, I'd also like to gain an inch or two so it sits level with the front. If I did go with the longer bags couldn't I just use a lower pressure it it turns out it's too high?
1989 Montero 4dr V6 3.0l
Re: Coil Spring airbags [Re: 89montero] #992752 04/10/10 07:40 PM
well they came in yesterday and I've got them installed. Right now they're hooked up together w a T connector so you fill them both at the same time, this way it can flex off road. I was reading in another post that someone installed a valve where you can switch between open and closed, but when it's closed it lets the pressure equalized before it locks.
Anyone have a link for one of these, doesn't need to be electric, I don't mind getting out to switch it. Basicly I want it locked on road and open off road.
Anyway, I did buy the longer bags and I'm glad I did, for me they seem to be perfect. When pumped to 35 psi the back end is a little taller than the front even w the tbars cranked(looks pretty cool). Also you can put as much weight as you want back there and it doesn't sag.
Overall it was a great $75 investment. Also I installed the filler valve inside the gas tank door so it's easy to get to but still covered up.
Re: Coil Spring airbags [Re: 89montero] #992753 04/10/10 07:47 PM
Where'd you find it for only $70 and did that also include a compressor?
Re: Coil Spring airbags [Re: off-roader] #992754 04/10/10 08:11 PM
bought it through amazon.com for $75. No compressor I installed the fitting behind the fuel door and just fill it with a tire pump.
Re: Coil Spring airbags [Re: 89montero] #992755 04/12/10 05:05 PM
does anyone have a link to the isolator valve?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6424 MB (Peak: 0.7512 MB) Data Comp: Off Server Time: 2026-11-17 11:22:15 UTC
