Page 1 of 3 1 2 3
Coil Spring airbags #992736 04/04/10 12:35 AM
89montero Offline OP
The rear coils in my LWB are starting to sag and that combined with the tbars cranked means I sit pretty low in the back and if I have a load or any trailer larger than my jetski it sits VERY low.
I read some posts on here where people recommended airlift airbags that go in the coils. Seems like the perfect solution because I could pump it up to a 1-2" lift to level out w the front and could pump it up even more to level a large load or bigger trailer.
Most threads seemed to be about using them on a gen2. Does anyone know the part number for a LWB gen2? Also someone mentioned to get one that was a couple inches longer than whats recommended for the stock coils(I assume this is to get more lift), any input on that?
1989 Montero 4dr V6 3.0l
Re: Coil Spring airbags [Re: 89montero] #992737 04/04/10 01:25 AM
Happy Birthday hazy_daze Offline
My recommendation would be to get a pair of GenII coils and put in there. That'll give you back a little lift and they're progressive rate to boot. Reuben runs the airlifts on his GenII, maybe he'll chime in with his experience. I thought there was somebody in a GenI that them too...
Re: Coil Spring airbags [Re: hazy_daze] #992738 04/04/10 01:38 AM
I've been keeping an eye out for those at pull-a-part but haven't gotten a pair yet. I'm sure they'd help but I feel the airbags would really be the best solution(maybe in combination w gen2 springs). With the bags I could keep it level even when I have a bunch of stuff in the back or a trailer.
Re: Coil Spring airbags [Re: 89montero] #992739 04/04/10 03:53 PM
justice Offline
Gen 1 and two use the same diameter coil spring so the airbags will be the same for both.
Re: Coil Spring airbags [Re: 89montero] #992740 04/04/10 05:58 PM
PHIL_ Offline
I have them in a genII with spacers too. I'll have to find the part number for you...
Re: Coil Spring airbags [Re: 89montero] #992741 04/04/10 07:20 PM
motero Offline
I have been running them for years, great load capacity. But if you wheel a lot, I have rubbed holes in a couple of them. You can buy replacement bags separately. I have gone through a few. Great fix for what you are looking for, but not the final answer.
Check out Michigan truck springs. Never had a problem buying from them.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Coil Spring airbags [Re: motero] #992742 04/05/10 01:41 AM
sasnydley Offline
I have have air bags in mine and works great.
Re: Coil Spring airbags [Re: sasnydley] #992743 04/05/10 01:52 AM
You're who I was thinking of.
Re: Coil Spring airbags [Re: hazy_daze] #992744 04/05/10 02:57 AM
Mad_Scientist Offline
I've got them in mine with coil spacers too. They're great.
Re: Coil Spring airbags [Re: Mad_Scientist] #992745 04/06/10 09:52 PM
Cool well I think I'll go ahead and order them when I get paid next. Way it is now even with 200lbs of cargo in the back and no other people the rear end sits on the bumpstops.
I was reading this thread http://www.4x4wire.com/forums/showflat.p...true#Post344583 and in the second response they give the part number for slight;y longer bags. Any input on this? I would like to get about 1-2" of lift in the back so it's leveled with my cranked Tbars up front. Also I think the montero PN is for a gen2 which have slightly shorter coils than the gen1 so that's another reason for going with the longer ones.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6410 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-06-23 05:36:55 UTC
