Coil Spring airbags
#992736
04/04/10 12:35 AM
The rear coils in my LWB are starting to sag and that combined with the tbars cranked means I sit pretty low in the back and if I have a load or any trailer larger than my jetski it sits VERY low. I read some posts on here where people recommended airlift airbags that go in the coils. Seems like the perfect solution because I could pump it up to a 1-2" lift to level out w the front and could pump it up even more to level a large load or bigger trailer.
Most threads seemed to be about using them on a gen2. Does anyone know the part number for a LWB gen2? Also someone mentioned to get one that was a couple inches longer than whats recommended for the stock coils(I assume this is to get more lift), any input on that?
1989 Montero 4dr V6 3.0l
Re: Coil Spring airbags
[Re: 89montero]
#992737
04/04/10 01:25 AM
My recommendation would be to get a pair of GenII coils and put in there. That'll give you back a little lift and they're progressive rate to boot. Reuben runs the airlifts on his GenII, maybe he'll chime in with his experience. I thought there was somebody in a GenI that them too...
[Re: hazy_daze]
#992738
04/04/10 01:38 AM
I've been keeping an eye out for those at pull-a-part but haven't gotten a pair yet. I'm sure they'd help but I feel the airbags would really be the best solution(maybe in combination w gen2 springs). With the bags I could keep it level even when I have a bunch of stuff in the back or a trailer.
[Re: 89montero]
#992739
04/04/10 03:53 PM
Gen 1 and two use the same diameter coil spring so the airbags will be the same for both.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: 89montero]
#992740
04/04/10 05:58 PM
I have them in a genII with spacers too. I'll have to find the part number for you...
[Re: 89montero]
#992741
04/04/10 07:20 PM
I have been running them for years, great load capacity. But if you wheel a lot, I have rubbed holes in a couple of them. You can buy replacement bags separately. I have gone through a few. Great fix for what you are looking for, but not the final answer.
Check out Michigan truck springs. Never had a problem buying from them.
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: motero]
#992742
04/05/10 01:41 AM
I have have air bags in mine and works great.
[Re: sasnydley]
#992743
04/05/10 01:52 AM
I have have air bags in mine and works great. You're who I was thinking of.
[Re: hazy_daze]
#992744
04/05/10 02:57 AM
I've got them in mine with coil spacers too. They're great.
[Re: Mad_Scientist]
#992745
04/06/10 09:52 PM
Cool well I think I'll go ahead and order them when I get paid next. Way it is now even with 200lbs of cargo in the back and no other people the rear end sits on the bumpstops. I was reading this thread http://www.4x4wire.com/forums/showflat.p...true#Post344583 and in the second response they give the part number for slight;y longer bags. Any input on this? I would like to get about 1-2" of lift in the back so it's leveled with my cranked Tbars up front. Also I think the montero PN is for a gen2 which have slightly shorter coils than the gen1 so that's another reason for going with the longer ones.
