Re: Parting 95 Montero SR
[Re: SRTNate]
#992864
04/19/10 11:01 PM
Have you got the head light washer/sprayer ???pass side ,but i dont think it makes a differance ....thanks .
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
[Re: SRTNate]
#992865
04/20/10 04:27 AM
How much for the front brakes?
[Re: MarkG]
#992866
04/20/10 04:39 AM
How much for the front brakes? FYI the montero SR brakes have a larger thickness I believe that makes the calipers only work with there rotors or something like that. In case your hoping for just a simple caliper swap <img src="/forums/images/graemlins/cheers.gif" alt="" />
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#992867
04/21/10 01:38 AM
How much for the front brakes? FYI the montero SR brakes have a larger thickness I believe that makes the calipers only work with there rotors or something like that. In case your hoping for just a simple caliper swap <img src="/forums/images/graemlins/cheers.gif" alt="" /> I've got the GenII calipers clamping GenI rotors. They work fine. Mark, you will want the backing plates from the GenII or judicious usage of tin snips on the GenI ones will work to. There's also a little rejiggering of the short hard line to do. I can come help when you're ready to do that swap...
[Re: SRTNate]
#992868
04/21/10 02:16 AM
Nate ...I am also interested in the grill ...as well as the headlight washer <kb2iaw@cyberoutback.com> thanks .
[Re: KB2IAW]
#992869
06/08/10 02:03 AM
I need the rear tailgate outside door handle Thanks Russ
GETTIN OLD THATS EARNED Happy trails to you (1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear (2)95 4Runner All Pro Nerf bars BFG 32s ARB bull bar Downey 2" rear coils Downey headers (3) 90 Montero LWB 3.0 auto (4) 98 Kawi GPZ1100
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6167 MB (Peak: 0.7028 MB) Data Comp: Off Server Time: 2026-06-17 14:26:55 UTCValid HTML 5 and Valid CSS
