Oil Leak?
#993473
04/11/10 09:17 AM
So it seems the engine i bought had an oil leak coming from underneath the intake manifold. there is this area with two bolts holding on a plate like thing(sorry for the bad description)that isn't on the engine that was in the raider. that seems to be where the leak is coming from. the "new" engine was from a 86 or 87 d-50. is there like a gasket that could be leaking oil there or something?
88 Dodge Raider 1.5" lift 32"X11.5" A/T tires 15X10 vintage enkei's
Re: Oil Leak?
[Re: Angrybooger2]
#993474
04/11/10 03:15 PM
Has the fuel pump been changed to an electric replacement? If so, the "plate" may be blocking the hole for the OE mechanical pump.
Frank
Re: Oil Leak?
[Re: Angrybooger2]
#993475
04/11/10 03:15 PM
Fuel pump gasket or the fuel pump can leak oil. If you dont have a pump on the engine it might be a block off plate.
Re: Oil Leak?
[Re: Kevin C]
#993476
04/11/10 09:12 PM
the fuel pump seems to be ok and it's regular mechanical pump. hold on im going to take some pictures.
Re: Oil Leak?
[Re: Angrybooger2]
#993477
04/11/10 10:10 PM
Re: Oil Leak?
[Re: Angrybooger2]
#993478
04/11/10 10:31 PM
Thats the ballance shaft cover thats leaking.
Re: Oil Leak?
[Re: Kevin C]
#993479
04/12/10 12:58 AM
OH! <img src="/forums/images/graemlins/kewl.gif" alt="" /> ok thanks, how would i go about fixing it?
