Page 1 of 3 1 2 3
Brake fluid leak - fluid on tire #993688 04/13/10 01:15 PM
RobCambo Offline OP
Can anyone help out with this one?
I looked across the road at the car and noticed a wet patch on the bottom of the inside of the tire wall under the car - back passenger side. My first thought was a small dog had gone under the truck and pissed there, but I looked again an hour later it was still wet. Took a closer look and I think perhaps a brake line/cylinder seal has gone and it's dumped a large amount of fluid into the wheel and then it's pooled up and overflowed down the tyre wall. Will the fluid have damaged the tire at all? (Goodyear Wrangler.)
Many thanks
Rob
1986 Pajero 2.6l 5spd manual SWB
http://s690.photobucket.com/albums/vv265/RobCambo/
Re: Brake fluid leak - fluid on tire [Re: RobCambo] #993689 04/13/10 01:44 PM
RECON45 Offline
If it is brake fluid it would not harm the tires. the big thing is that the fluid did not get slug up on the rotors (if you have disc brakes) and get on the pads. that can mess with braking.
Re: Brake fluid leak - fluid on tire [Re: RECON45] #993690 04/13/10 02:24 PM
RobCambo Offline OP
That's good to know, thanks very much.
Drums on the rear - I'll check it out when it's light tomw.
Cheers.
Re: Brake fluid leak - fluid on tire [Re: RobCambo] #993691 04/13/10 04:10 PM
8
89IsMine Offline
... Took a closer look and I think perhaps a brake line/cylinder seal has gone and it's dumped a large amount of fluid into the wheel and then it's pooled up and overflowed down the tyre wall...
If that's the case then before you do anything else check the fluid level in the master brake cylinder!!! If you've got that much fluid leaking out due to a component failure you may well be in danger of losing your brakes entirely due to fluid loss <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Eric W.
Re: Brake fluid leak - fluid on tire [Re: 89IsMine] #993692 04/13/10 04:35 PM
RobCambo Offline OP
First thing I did was find someone to stand on the brake pedal while I looked at the wheel - nothing dripped or ran out.
Next I checked the reservoir in the engine bay - levels looked good, the same as when I checked on Sunday.
Cleaned up the pool in the wheel then started the moter and pumped the brakes, a little soft on first push then hard - normal, and no fluid leak.
I got the car home ok and have parked her up with the old leak mark at the top of the wheel. Will check in the morning if it's leaked again and will strip the corner down and check it all through.
Re: Brake fluid leak - fluid on tire [Re: RobCambo] #993693 04/13/10 05:21 PM
RECON45 Offline
Not to scar you but, in my old 69 Bronco I had a leak with the drum breaks and it was leaking inside the drum so it took awhile to see fluid come out, and it was a mess. it probably would not hurt to take the tire off and pull the drum and check whats going on the inside.
Re: Brake fluid leak - fluid on tire [Re: RECON45] #993694 04/13/10 09:04 PM
If it washes off with water and turns milky in the process, it's likely brake fluid. If the water beads up, it's likely axle lube and you need an axle seal. If a dog sniffs it and whizzes on it, its....
Re: Brake fluid leak - fluid on tire [Re: fasteddy] #993695 04/14/10 06:21 AM
RobCambo Offline OP
Well, the dogs took no interest,
and there was no further leakage overnight,
the tire was a mess but cleaned up with water and a little soap - the fluid didn't repel water,
fluid seems to have climbed up the back for some reason...
Can't get past this stage as it's on solidly, so the next question is right out of the stupid box...
Where can I find 2 x 8mm bolts on a Pajero?
I don't have any laying around, the shops/markets are closed for a week for Khmer New Year and I can't find any that fit from the truck.
Re: Brake fluid leak - fluid on tire [Re: RobCambo] #993696 04/14/10 06:31 AM
$50 its your drum brake cylinder. <img src="/forums/images/graemlins/smile.gif" alt="" /> If stores are closed, you prob wont be able to get a new one till they open anyway.
Re: Brake fluid leak - fluid on tire [Re: off-roader] #993697 04/14/10 06:53 AM
RobCambo Offline OP
I had all the brakes serviced and new cylinders and shoes fitted on both rear wheels on 30th January this year. If it is the cylinder, there may be trouble ahead...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6454 MB (Peak: 0.7703 MB) Data Comp: Off Server Time: 2026-06-21 15:59:18 UTC
