Page 3 of 3 1 2 3
Re: Brake fluid leak - fluid on tire [Re: fhuzz] #993708 04/16/10 08:03 PM
StockRaider Offline
the V6 brakes might be bigger anyways. Better to just order them for your vehicle.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Brake fluid leak - fluid on tire [Re: StockRaider] #993709 04/16/10 11:12 PM
bodyswapped8789 Offline
Edit, I don't want to go off topic. But is your garage floor real tile? How did you jack the rear wheel off the ground without cracking it? <img src="/forums/images/graemlins/lol.gif" alt="" /> I would love to have a tile floor for easy cleanup, but I would have to install a lift in my garage to keep from breaking it. <img src="/forums/images/graemlins/lol.gif" alt="" />
Funny I was asking myself that exact same question!
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: Brake fluid leak - fluid on tire [Re: RECON45] #993710 04/16/10 11:24 PM
Maybe someone can chime in if I am wrong but with the american drum car there is an adjuster at the bottom of the drum assembaly and it needs to be adjuster when everything is back togethor so that the pads just barely touch the drum when you turn the wheel. Good luck with it. At least you are on the right track and should have it fixed no time.
Adjuster is at the top, right under the wheel cylinder, Funny I just noticed the exact same thing on my own truck. I did my own brakes and I am very anal so don't beat up the shop too bad. I blame mine on trying to save a few bucks. And actually it is a 12mm wrench for the wheel cylinder bolts and the bleeder/brake line is 10 mm. plus Spring tools are the best thing ever!!
Re: Brake fluid leak - fluid on tire [Re: RobCambo] #993711 04/17/10 01:18 AM
Stockraider - 10mm open for the brake line and bleed screw, 12mm closed for the cylinder, lots of swearing and a screwdriver for the 2 tiny circlips holding the handbrake cable parts.
Pliers work better, for the clips. I would need to take a picture to explain.
Re: Brake fluid leak - fluid on tire [Re: StockRaider] #993712 04/17/10 01:32 AM
That looks to be polished porcelain tile. In any case, most decent quality tile will hold up just fine in a garage as long as it is installed properly and a reasonable amount of care is used with tools.
Sorry for the hijack.
Re: Brake fluid leak - fluid on tire [Re: JohnnyBfromPeoria] #993713 04/17/10 02:12 AM
The trick is no voids in the mastic...
Re: Brake fluid leak - fluid on tire [Re: fasteddy] #993714 04/17/10 03:31 AM
You NEVER use mastic to adhere floor tiles of any size, Eddy, c'mon. Mortar.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6235 MB (Peak: 0.7194 MB) Data Comp: Off Server Time: 2026-06-22 07:31:18 UTC
