Re: anyone want a 4d56t? [Re: 87Montero] #993793 05/08/10 10:17 PM
Glock24 Offline
What are the differences in a motor manufactured by Hyundai vs. Mitsubishi? Any build quality changes or potential parts issues?
There are some minor differences between 4D56; Cylinder heads, valves and pistons are different between 4D56 manufactured before and after 1998, but the change also depends on the vehicle.
I know that the Hyundai D4BF is identical to 4D56T prior to 1998, the Hyundai D4BH is identical to the 4D56TDI present on the post-1998 L200 truck.
Almost everything is identical and interchangeable on Hyundai D4BF/H and Mitsubishi 4D56, except for some accessories like alternator and alternator belt.
Also, there are some variation on the turbos. Some models are water and oil cooled, some others are only oil-cooled. Most old 4D56 I've seen are oil-cooled only. Most D4BH and later 4D56 I've seen are water and oil cooled. Also, some newer 4D56 engines have variable geometry turbos and electronic fuel pump, producing 115HP instead of 100-105HP.
I would say build quality on the D4BF/H is a non-issue.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: anyone want a 4d56t? [Re: Glock24] #993794 05/27/10 07:52 AM
bellavesus Offline OP
that is great information, thank you for that! well, the time is coming for the order-changed suppliers, now they come from japan, via malaysia! used 4d56t's with 4wd MT and 4jb1t's with 4wd MT as well. cost on the 4jb is higher than the 4d56, pm or email me
wriincorporated@gmail.com
86 Turbo Diesel 4dr Trooper 4JB1TC
89 turbo diesel Trooper-RED
Re: anyone want a 4d56t? [Re: bellavesus] #993795 03/23/11 08:09 PM
JeffatTireBalls Offline
What ever happened with this deal?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5996 MB (Peak: 0.6543 MB) Data Comp: Off Server Time: 2026-06-20 20:09:54 UTC
