rebuilding a 97 3.5 liter 24 valve motor #994063 04/17/10 03:00 AM
ghostwalker Offline OP
well guys i am going to be rebuilding my 3.5 v6 i have removed it from the truck and have tore it down it had sat for ten years before i got it the block had got some moisture in 3 of the cylinders and the bore rusted some and when i fired it up the rings wouldnt seal it would run fine but had not much power and when i would drive it it would jerk like it needed a tune up i did all the tune up stuff plugs wires coils packs fuel filter this block only had 40k on it when it was parked what a shame now its going to have to be bored and new ring and bearings ill post some pictures at a l8ter date and time
do you feel lucky
Re: rebuilding a 97 3.5 liter 24 valve motor [Re: ghostwalker] #994064 04/17/10 03:19 AM
Va_Stumpy Offline
God luck, be patient, keep it clean & check behind your engine shop no matter how much you trust them. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: rebuilding a 97 3.5 liter 24 valve motor [Re: ghostwalker] #994065 04/17/10 03:23 AM
You may not need to bore it over. Why not try breaking the glaze off with a cylinder hone first, then fitting new rings and end filing the gaps? Stick some new bearings in and check with plastiguage and go from there? Just a thought.
Re: rebuilding a 97 3.5 liter 24 valve motor [Re: JohnnyBfromPeoria] #994066 04/17/10 03:28 AM
there is no glaze in the bore but there is some mild pitting
do you feel lucky
Re: rebuilding a 97 3.5 liter 24 valve motor [Re: ghostwalker] #994067 04/17/10 03:30 AM
Gotcha.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6059 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-06-12 11:50:31 UTC
