Re: D.O.A. in the garage [Re: BamZipPow] #994224 04/24/10 12:05 PM
CJMT100 Offline
Crank heck out of it and try giving it gas at multiple pedal presses (hold half, hold full, let off etc).
Remove a plug wire, put screwdriver into the socket and lay on head-have someone crank and watch for spark-if it has it the spark will arch off the screwdriver onto the metal.
Of course listen for fuel pump, if all else fails someone cranks and you smack the tank with a hammer and it might work if the pumps going.
Re: D.O.A. in the garage [Re: Nodelk] #994225 04/24/10 02:13 PM
Dandeman Offline
Toyota Moderator
After you have followed kewlynx comments to rule out electrical problems and that the fuel pump is getting power, you need to check the fuel pump pressure..
Hard starting (and hesitation and bucking at full throttle under load) is an indicator of low fuel pump pressure. Low fuel pump pressure is a strong indicator of impending fuel pump failure.. Been there done that, and best that it happen while it's in the garage as opposed to on the road.
btw on the 3.4 engine, pumping the accelerator does nothing so far as priming the engine. accelerator pumps are long gone history..
The system depends upon the computer sensing a cold engine, knows the ignition switch is in the start position and fires the injectors a bit longer to prime the engine at start up; this system is set up for best starting with your foot off the accelerator with only idle air bleed as opposed to open throttle.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5932 MB (Peak: 0.6415 MB) Data Comp: Off Server Time: 2026-07-15 13:21:14 UTC
