Re: Gen 1 ARB bumper found in US but one question
[Re: toyhooter]
#994353
04/21/10 01:42 PM
OK. I get that there is a difference between the 4 cyl frame and the 6 cly frame. But ARB leaves out the 89 and 90 year models. Why? So what I think I hear is the ARB bumpers for 91 thru like 97 will work on a 90 LWB 6 cyl? Huh? With some help from spacers or a grinder? Huh? Because 89 and 90 were V6's. (well most 89's are and all 90's are) with the different frame. Now if you want to put the gen 2 Bar on your 89 that will work too but you'll need to grind off some of the inner mount on the ARB to get it to work as well as shaving the inside corners. Either way your gonna have to grind. Its just a matter of which bumper you prefer. ![[Linked Image]](http://gallery.me.com/zone1wst/100246/100_2891/web.jpg)
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#994354
04/21/10 09:55 PM
OK. I get that there is a difference between the 4 cyl frame and the 6 cly frame. But ARB leaves out the 89 and 90 year models. Why? So what I think I hear is the ARB bumpers for 91 thru like 97 will work on a 90 LWB 6 cyl? Huh? With some help from spacers or a grinder? Huh? Because 89 and 90 were V6's. (well most 89's are and all 90's are) with the different frame. Now if you want to put the gen 2 Bar on your 89 that will work too but you'll need to grind off some of the inner mount on the ARB to get it to work as well as shaving the inside corners. Either way your gonna have to grind. Its just a matter of which bumper you prefer. I had this exact same question for my 1989 V6 SWB. Sounds like the Gen II bumper is the best one to modify if it is a V6? Justice, do you have any other pics of this truck? I am curious about the width and how it lines up with the fenders. I like that the Gen II bumper wraps around the front where the Gen I does not. Thanks
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's 2005 Mitsubishi Montero Limited 3.8 V6 2011 Subaru Impreza Outback Sport
[Re: 89Montiero]
#994355
04/21/10 10:16 PM
Check out my thread, "Project El Gato" for more pics.
[Re: justice]
#994356
04/22/10 01:12 AM
I also have a Gen1 with a Gen2 Bumper on it.
I modified my frame rails to fit. I basically welded plate on my frame, and built Gen2 Frame horns onto my Gen1 Chassis.
[Re: LandRaider]
#994357
04/22/10 01:16 AM
[Re: LandRaider]
#994358
04/22/10 02:55 AM
The frame horns are different between the 4 cyl frames and the 6 cylinder frames. The 6 cyl horn is wider than the 4 cyl horn. Almost 10 years ago I purchased an ARB winch bumper for a Gen I 4 cyl. I took the bumper and truck to a machine shop and they cut out the plate circled in [color:"red"] red [/color] and moved it toward the center about 1 inch. They then added a plate to the top and bottom to keep the box intact around the frame. The plate in [color:"yellow"] yellow [/color] does not move. ![[Linked Image]](http://pics.montypics.com/markg/2010-04-21/1271900865_bumper2.jpg)
[Re: BoiseMontero]
#994359
04/23/10 06:05 PM
OK, now that you've figured this out.. does that place actually have them in stock? I know ARB no longer does and I'd be surprised if the place you found has them. <img src="/forums/images/graemlins/frown.gif" alt="" />
