thread size for the oil pressure
#994462
04/21/10 05:21 PM
looking for the size of the oil pressure sending unit. I have a autometer ele. gauge and looking for the adapter for the sending unit. any idea? thanks they said it a 1/8 brittish
many thanks loren
92 montero rs 3.0 locked rear
Re: thread size for the oil pressure
[Re: shawnsdad]
#994463
04/21/10 05:35 PM
Correct, 1/8 Britt pipe. I have dressed the threads to 1/8 NPT in the past.
[Re: OldColt]
#994464
04/21/10 06:12 PM
nope wont fit!!!!! or is it a bear to get in there?
many thanks loren
[Re: OldColt]
#994465
04/21/10 06:13 PM
Get a 1/8 NPT tap and rethread it, or get a 1/8th NPT to 1/8 BSP adapter. 1/8 NPT is 27 TPI and 1/8 BSP is 28 TPI.
[Re: shawnsdad]
#994466
04/21/10 06:29 PM
Do you have British straight pipe or British taper pipe?
These are taper pipe. Straight will not work.
[Re: OldColt]
#994467
04/21/10 06:55 PM
I got it in there!!!!!!!!!!!!! its not leaking. I have the adapter that autometer says to get. its a 1/8 to a 1/8 british. part number 2269. and I called them 3 times and they ask for make and model. and they would get back to you. still waiting... the new adapter is not tapered. but it in there. and working
many thanks loren
[Re: shawnsdad]
#994468
04/21/10 07:30 PM
ok got the call back. that is the only one they have for that app. I told him about the taper 1/8 britt. they told me to go to earls.... nice.
many thanks loren
[Re: shawnsdad]
#994469
04/21/10 07:47 PM
[Re: OldColt]
#994470
04/21/10 09:13 PM
sweet thanks. kinda wierd that autometer never had a problem..
many thanks loren
