Parked for 2 years, fluids OK? #994650 04/22/10 05:52 PM
The_Rusty_Gear Offline OP
Truck has been parked for a little over two years. I changed the oil and antifreeze a few months before storage. I started it every few months to get everything "wet" and maintain battery charge. It started up great when I took it home last week!
Should I be concerned about any of the fluids sitting for so long? (Oil sits in the bottle for years, right?)
I know the "best thing" to do is change ALL fluids, but the truck will get very intermittant use (maybe one short trip a week) and I don't think I can justify the cost of total fluid replacement.
I had to top up the brake fluid (MC did not go dry) so there is likely a small leak somewhere I will need to track down, and the only other problem is my washer pump does not seem to be working (press the button and no sound of motor) Probably rusted and needs replacement. . .
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Parked for 2 years, fluids OK? [Re: The_Rusty_Gear] #994651 04/22/10 07:06 PM
G
Greg_Canada Offline
Definately change the enigne oil! the additives break down after a year...
as for diff and t-case and tranny... i'd change them if i were you...
89 4Runner
Re: Parked for 2 years, fluids OK? [Re: The_Rusty_Gear] #994652 04/22/10 11:19 PM
Dandeman Offline
Toyota Moderator
Brake fluid is hydroscopic.. meaning it will absorb moisture.. Moisture causes corrosion especially wheel cylinders, which in turn causes seal failures and leaks..
Since I've been flushing new brake fluid through the system every 2 years, have not had any brake component or seal failure..
Before that, used to have them every so often.
Re: Parked for 2 years, fluids OK? [Re: Dandeman] #994653 04/23/10 04:46 AM
kewlynx Offline
x2 on the brake fluid. Includes clutch system too, if applicable.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 2.819s Queries: 15 (0.003s) Memory: 0.6030 MB (Peak: 0.6595 MB) Data Comp: Off Server Time: 2026-06-07 08:50:56 UTC
