Deteriorating Crossmember?? #994790 04/24/10 01:03 AM
WigWiggy Offline OP
Just got finished pulling the crossmember to do a trans fluid/filter change and found it's REALLY rusty where it contacts the frame rails. At first I thought the flaky rust chunks were remnants of some sort of gasket...(they aren't...right?). The pics don't do it justice but some of the flakes are a good 1/8th inch thick. What, if anything, should I do when I reassemble this? Should I try to reposition what's left of the rust flakes and just sandwich them back in place? Maybe make a loctite and rustflake sandwich?
98 Montero, 184k.
Re: Deteriorating Crossmember?? [Re: WigWiggy] #994791 04/24/10 01:39 AM
Move somewhere civilized where snow isn't an issue during the winter. <img src="/forums/images/graemlins/smile.gif" alt="" />
Seriously I'd consider buying a replacement cross member from car-part.com. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Deteriorating Crossmember?? [Re: off-roader] #994792 04/24/10 03:23 AM
Va_Stumpy Offline
Just ride the wave til it hits the beach!
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Deteriorating Crossmember?? [Re: Va_Stumpy] #994793 04/24/10 05:17 AM
justice Offline
Wire brush the Pi$$ out of it, paint with some rustoleum and reassemble. Keep an eye out for a new crossmember next time your at the yard.
Re: Deteriorating Crossmember?? [Re: justice] #994794 04/24/10 12:10 PM
P
pcc Offline
I'd also use a rust converter on it prior to painting and also clean/paint the frame where the crossmember bolts. Also don't know if you can get a product called "Rust Check" where you are but it is great for stopping/preventing rust. I've used it for years and it creeps into the smallest places to get at the rust.
PHP: 7.4.33 Page Time: 0.435s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-06-06 07:33:45 UTC
