Page 2 of 13 1 2 3 4 12 13
Re: 3.5L 6G74 into a Gen 1 [Re: SRTNate] #995333 04/30/10 02:24 AM
StockRaider Offline
I am very interested in your progress... I think since my Raider doesn't have its original engine I will go 3.5 when rebuild time comes. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 3.5L 6G74 into a Gen 1 [Re: SRTNate] #995334 04/30/10 03:31 AM
SRTNate Offline OP
The engine mounts are about ready to be welded, I just wanted to quadruple check how things are lined up when I'm a bit less tired. Now that the engine is held rigidly side-to-side, it gives me a much better view of how things are shaping up...and the situation looks good.
I may have made the second cut to the oil pan a bit prematurely, but the engine may not be in it's final vertical position. And I know I need to allow for some sag from the rubber in the mounts once they're supporting the full weight of the engine.
To elaborate on some earlier transmission questions:
The G1 transmission/tcase, from bellhousing to output cup, is about 43-44 inches. (it was awkward to measure while in the truck)
The G2 Transmissionfercase, measured the same way, is 50 inches.
With the G1 setup, the distance from the output cup to the pinion is 23 inches. So, I assume with the G2 setup it would be about 16 inches, and at a much steeper angle.
Re: 3.5L 6G74 into a Gen 1 [Re: SRTNate] #995335 04/30/10 06:09 AM
I knew we were gonna have some fun when Nate got going good...
Re: 3.5L 6G74 into a Gen 1 [Re: fasteddy] #995336 04/30/10 06:06 PM
And...what will the power output of the 3.5L be?
Re: 3.5L 6G74 into a Gen 1 [Re: fasteddy] #995337 04/30/10 06:54 PM
hazy_daze Offline
Nate, give me a call if you need anything that I can provide thru my parts channels. I can also come wrench if that'd help...
Re: 3.5L 6G74 into a Gen 1 [Re: rxinhed] #995338 04/30/10 07:27 PM
justice Offline
215 HP in stock config.
Re: 3.5L 6G74 into a Gen 1 [Re: justice] #995339 04/30/10 07:33 PM
W
willwinchforfood Offline
I hear if you put diamante pistons in the 3.5 you can get over 700 hp on pump gas.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: 3.5L 6G74 into a Gen 1 [Re: willwinchforfood] #995340 04/30/10 07:51 PM
hazy_daze Offline
That's incorrect. On premium, it's 700. It's only 675 on 87...
I used the search function to find that info, BTW.
Re: 3.5L 6G74 into a Gen 1 [Re: willwinchforfood] #995341 04/30/10 07:59 PM
SRTNate Offline OP
Interesting...interesting...I'll have to look into that.
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
Re: 3.5L 6G74 into a Gen 1 [Re: SRTNate] #995342 04/30/10 09:30 PM
StockRaider Offline
I think he is referencing me grilling him on the 3.0 Raider on the for sale section where he said it had 200hp with diamante pistons. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6507 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-06-07 02:29:54 UTC
