Oil pan removal #995624 05/01/10 12:52 AM
JohnnyMontero Offline OP
I have a 91 v6 LWB. My oil pan is leaking quite heavily due to the previous owner not knowing what he was doing.
Is there any way I can remove the oil pan to replace the gasket without lifting the engine?
Thanks all
~JM
Re: Oil pan removal [Re: JohnnyMontero] #995625 05/01/10 03:02 AM
Inyo_man Offline
I'm not sure about the Gen II, but in my Gen III you can get to it from the bottom. It's a pretty involved project.
You have to drop the front diff. to get at it, but that's much easier than pulling the engine.
Good Luck
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: Oil pan removal [Re: JohnnyMontero] #995626 05/01/10 03:26 AM
Va_Stumpy Offline
I have a gen I... couldn't figure a way to do it without pulling the engine or dropping the front axle. Good luck!
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Oil pan removal [Re: Va_Stumpy] #995627 05/01/10 04:34 AM
I think willwinchforfood and I got his off by dropping the front diff carrier on one end and the crossmember. Had to fish it a little, but it came out fine, until I twisted the head off one of those dinky little pan bolts...
Re: Oil pan removal [Re: fasteddy] #995628 05/01/10 04:37 PM
Happy Birthday hazy_daze Offline
If you don't have access to an engine hoist, then dropping the front carrier is the only way. If you do have access to one, lifting is the way to go. It can be done either way, but IMHO lifting is the easier of the two.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-23 18:42:24 UTC
