Code P101 out of ideas any help welcome #995756 05/03/10 12:46 AM
jon1983 Offline OP
99 Sportage that has me puzzled. Symptoms Stumble off idle and no power. You can drive it just fine but it feels like it is down 20hp. I had codes checked and I have 2. I have code p101 and p172. IÆm pretty sure p172 is O2 sensor. I have been trouble shooting the p101 all day and IÆm out of ideas. So far I have done the following:
Soldered connections to eliminate plug
Tested voltage Per Kia global Service instructions
1. Warm up the engine to normal operating temperature and let it idle.
2. Connect a voltmeter between terminal 4 (RED/GRN wire) and ground.
3. Verify that the voltage varies between 0.8V-1.2V.
4. Rev up the engine and verify that voltage varies between 3.5V-4V.
5. If the voltage is not within specification, replace the mass air flow sensor.
#3 I have 1.3V
#4 tops out at 3.5V as I rev engine
I pulled out ECU and checked for continuity between MAF and Pin 14 and pin 41 and everything checked out.
I tested the TPS for resistance and it is in spec 2.4 closed dropping to 1 as opened.
IÆm willing to try just about anything but have run out of ideas. Any thoughts would be welcome.
Re: Code P101 out of ideas any help welcome [Re: jon1983] #995757 05/03/10 01:21 AM
homerdog Offline
check for a plugged catalytic converter
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Code P101 out of ideas any help welcome [Re: homerdog] #995758 05/03/10 02:06 AM
Everet Offline
Code 172= Bank one system too rich
Code 101= Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
KIA CEL CODES
Check the connections on the MAF per Axe's instructions. See if that helps.
If your running rich, you may have an injector partially stuck open which will make it run like crap.
Keep us informed.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5908 MB (Peak: 0.6444 MB) Data Comp: Off Server Time: 2026-06-07 18:13:29 UTC
