power steering question
#996074
05/07/10 01:34 AM
Ok 1st of I'm broke right now so I am trying to be cheap. My powersteering box on my truck...87 ram 50...was leaking bad so I found one off a montero...V6...well the fittings are different....the question is could I just block the lines and fill the pump and seal the fittings and use it as non power steering....The old one was leaking so bad I didn't have powersteering most of the time anyway
1987 Dodge Ram 50 2.6 5 speed 2 inch body lift 31x11.50 Swamper LTBs 4.62 gears lsd rear and welded front with lockouts Weber carb waiting to be installed
Re: power steering question
[Re: Red1979]
#996075
05/07/10 02:06 AM
you might be able to use the V6 pump as trading stock for a 4 banger pump. WHat seal exactley is leaking? IIRC if its just thr front seal, chicago rawhide make s a seal for it, you need to get the part number off of it though.
always working
[Re: Macka]
#996076
05/07/10 02:19 AM
the seal where the arm goes in the bottom is leaking. I dont really need powersteering so I was wondering if I could put fluid in the gear box and seal it off and not really have it as power steering
[Re: Red1979]
#996077
05/07/10 09:18 PM
That seal cheap and pretty easy to change. Mine leaked, and I got it stopped with ps fluid with stop leak in it, but my leak was pretty minor. No to the gear oil fix - incompatible fluids and the seals will probably seize up.
[Re: fasteddy]
#996078
05/07/10 11:44 PM
i just went to the junk yard and got a used one...something is still squealing gotta find that now....sounds like it is coming from the drivers side
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6047 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-06-24 20:11:18 UTCValid HTML 5 and Valid CSS
