throttle body won't budge @#$%^&* #996351 05/09/10 01:44 AM
MAC Offline OP
87 22re. Trying to pull my throttle body off to relace TPS.
Unbolted 4 places... won't budge. I smacked it repeatedly in multiple directions as hard as I dare with a plastic mallet to no avail. Thinking of soaking the mating joint with something...acetone, Kroil, Pepsi..??
Don't see any good pry spots right off either. Anyone been there?
Re: throttle body won't budge @#$%^&* [Re: MAC] #996352 05/09/10 08:58 PM
toyrunner Offline
Use a punch and tap towards the front of the motor. It will come off. I tapped at the top on the bell crank side and on the TPS side at the boss for the TPS. Not too hard of a smack. Just a persuasion.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: throttle body won't budge @#$%^&* [Re: toyrunner] #996353 05/10/10 12:52 AM
RatLabGuy Offline
It's been about 6 years, so my memory is fuzzy - but isn't there some hidden bolt that goes through a coolant jacket or something?
Doest he FSM posted here show only 4 bolts?
I do remember mine being really stuck on also though.
Question Reality.
Re: throttle body won't budge @#$%^&* [Re: RatLabGuy] #996354 05/10/10 09:49 PM
MAC Offline OP
well... I held my breath and rapped it harder using a piece of hardwood between the BFH and the housing.... it finally popped off. (no hidden bolt...just the 3 bolts and nut on a threaded stud). The gasket is really adhered to the manifold... as if sealer was used but as far as I know it is original. I guess the years under pressure bonded it. No torque spec in the FSM for the bolts. I'm thinking only 9 ft/lbs or so ? Growing up back when aluminum was rare on an engine I always want to overtighten....
Re: throttle body won't budge @#$%^&* [Re: MAC] #996355 05/10/10 11:38 PM
toyrunner Offline
German engineering, gudentite!
<img src="/forums/images/graemlins/cyclops.gif" alt="" />
1985 SR5 4Runner
4.7:1 single case
Re: throttle body won't budge @#$%^&* [Re: RatLabGuy] #996356 05/11/10 02:22 AM
kewlynx Offline
some hidden bolt
That's the famous 6mm allen bolt that drives you nuts if removing the whole intake manifold.
Glad ya got it; those old seals can be a bugger sometimes.
**ubi apis- ibi salus**
Re: throttle body won't budge @#$%^&* [Re: kewlynx] #996357 05/11/10 02:39 PM
MAC Offline OP
who are you calling an old seal ? smile
9 ft/lbs sound about right for those bolts?
Re: throttle body won't budge @#$%^&* [Re: MAC] #996358 05/11/10 02:47 PM
4Crawler Offline
The FSM has a table in one of the Appendices of torque specs for all the fasteners that do not list specific torques. Might check out that table (App. B in my '85 book).
PHP: 7.4.33 Page Time: 3.293s Queries: 15 (0.005s) Memory: 0.6234 MB (Peak: 0.7184 MB) Data Comp: Off Server Time: 2026-11-15 13:17:07 UTC
