Conv. EFI to Carb Concerns... #996386 05/09/10 04:26 PM
redman Offline OP
We have a '86 EFI truck going carb and getting concerned about the factory wiring harness...listed are the areas that seem to have potential problems;
1.) Ignition coil (can I keep or have to replace with carb. type)
2.) Elec. Choke (is there a wire than can be used off the factory harness that works in the same manner ex: as the engine temp. rises, the choke opens)
3.) Fuel pump (truck has in-tank elec. fuel pump that does not work, we are going mechanical and wondering if the pump will pick up fuel with the factory fuel pump remaining in the tank, or will we have to buy the mechanical fuel pump pickup?)
4.) ECU/ECM (will all factory computers have to remain plugged in to allow all elec. functions to opperate correctly, or can they be unplugged and removed?)
5.) Would it simply be wise to buy the factory harness for a carbed '86...lol
-Redman
Re: Conv. EFI to Carb Concerns... [Re: redman] #996387 05/09/10 04:28 PM
redman Offline OP
P.S. We do not have the factory throttle body/intake manifold so recommending to stay EFI isnt possible smile
Plus, we are a bunch of carb heads anyhow haha
Redman
Re: Conv. EFI to Carb Concerns... [Re: redman] #996388 05/11/10 01:35 PM
redman Offline OP
Ok, got the motor built and in...starts great, runs great can't seem to figure out why I'm not getting a temp. And got a Battery light on, new alternator and double-checked wiring smile
Thanks...
Re: Conv. EFI to Carb Concerns... [Re: redman] #996389 05/11/10 04:57 PM
matts Offline
Don't keep us in the dark! Tell how you dealt with the wiring and the ECU & stuff. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 1.249s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-06-24 12:47:16 UTC
