Re: Tell me about sump pumps [Re: rxinhed] #996447 05/12/10 02:02 AM
kewlynx Offline
Cool, glad you've got that figured out.
On the excavation job, take a good look at the seam between the exterior wall and the footing to see if that's all sealed up before tossing the drain in there. Typar over the gravel to keep the fines from clogging the pipes; should be all set.
Couple good things to lay your eyes on:
http://www.handymanwire.com/articles/drybasement.html
http://www.basementsystems.com/basement-waterproofing/basement-learning-center.html
**ubi apis- ibi salus**
Re: Tell me about sump pumps [Re: kewlynx] #996448 05/12/10 04:15 AM
The exterior walls around this particular basement are monolithic. The interior slab is floating and unreinforced. One half of the garage floor is the basement roof.
Figuring on at least a 10-11 foot trench alongside the basement wall, we're going to use 3/4" or 1" crushed, clean gravel to backfill over the perforated pipe, filter fabric to separate the gravel pack from the soil backfill, and compact. In addition, we'll be using Mira-drain, a bumpy plastic-backed filter against the wall, to provide drainage and aeration.
Re: Tell me about sump pumps [Re: rxinhed] #996449 05/12/10 05:10 AM
kewlynx Offline
I was just thinking too; the other thing your friend should consider is if the basement ventilation is adequate. If a house doesn't breathe, the living space isn't healthy. That's a big deal up here is indoor air quality.
Last, when's the last time she's had a radon test? Some places offer home test kits for free.
Re: Tell me about sump pumps [Re: kewlynx] #996450 05/12/10 05:46 AM
Wrong kind of bedrock for radon, metasedimentary rather than igneous. Secondly, I scoffed at the non-ventilation the space has. There is a dropped ceiling and ventilation will be installed during the reconstruction phase. All the wall board and ceiling materials will be removed shortly after the water has somewhere to go.
Re: Tell me about sump pumps [Re: rxinhed] #996451 05/12/10 07:13 AM
kewlynx Offline
Sounds like a plan is coming together.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6169 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-06-07 04:32:49 UTC
