BJ Spacer Lift Question #996456 05/10/10 04:27 PM
IceBlueT Offline OP
Hey guys, I know im in the wrong area, but no-one seems to be willing to answer in the t100 section so i figured i'd throw my question out here.
Recently installed the Toytec 2in. lift for the pickup/4runner/t100. It works fine, but i do have an issue. I currently have stock steel 16x7 rims off a 2003 tundra on the truck, and with the backspacing of the rim, there is only about 1/8 to 1/4 of an inch of space between the upper control arm and the sidewall of the tire. This is in all ranges of the suspension travel. I was wondering if you guys think that grinding down the little lip on the upper control arm would be enough to clear it, and still be safe. the lip looks to be the weld for the two pieces of the upper control arm.
thanks
If it helps, here is a picture of the control arm and steering knuckle.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: BJ Spacer Lift Question [Re: IceBlueT] #996457 05/10/10 06:10 PM
4Crawler Offline
Either grind if possible or run a small wheel spacer:
- http://www.4crawler.com/4x4/ForSale/BallJointSpacer.shtml#DISCLAIMER
Re: BJ Spacer Lift Question [Re: 4Crawler] #996458 05/10/10 08:23 PM
IceBlueT Offline OP
Thanks 4crawler. Unfortunately, Toytec provides no such disclaimer, so i was slightly miffed to find the lack of space. I will probably try grinding now, as that is the cheapest option.
Thanks
Re: BJ Spacer Lift Question [Re: IceBlueT] #996459 05/11/10 09:24 AM
Snowtoy Offline
You can get a set of Mr. Gasket wheel 1/4" spacers for under $20, maybe less locally.
PHP: 7.4.33 Page Time: 1.091s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6596 MB) Data Comp: Off Server Time: 2026-06-24 21:43:05 UTC
