Re: o2 sensor
[Re: sunder]
#997082
05/19/10 03:23 AM
yup did a tune up recently, i'm really not wanting to drop the tank, to change the filter, but i think i must, just to rule it out. i have a bad feeling about dropping the tank, like lots of stuff breaking to get it out.
oh the o2 was changed last yr as well.
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: o2 sensor
[Re: tcoff]
#997083
05/19/10 10:32 PM
You can do a half <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> flow test with the tank in the jeep.
Find the pressure test port on the fuel rail. Pull the protective cap and use a tire valve tool to remove the valve. Get some of that cheep clear vinyl hose and put it on the now open test port. Put the clear plastic hose in a bucket or something you know the volume of. Go to the relay center under the hood and pull the fuel pump relay. Study the little graphic on the relay and figure out which terminals to hotwire. Hot wire the terminals and watch the flow. I don't know the exact flow rate but it should be about 1/4-1/2 gallon per minute. Without an exact spec the "ouput" of the "test" is subjective. Just make sure there is a decent amount.
91 YJ 2 Seater Sand Rail Handfull of other fun toys... And a brand new, spit shined, B.S. Oh, and a job to boot.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6408 MB) Data Comp: Off Server Time: 2026-06-07 05:50:29 UTCValid HTML 5 and Valid CSS
